BigRed350x
    5
  1. Overnight for me too!
  2. K&T Custom Billet Intakes. Call K&T for a set!
  3. Yeah, I've been doing it that way since my 87 and have never had a problem with it. A top end will last me around 75 hrs on average, and i ride the piss out of my bike for the whole 75 hrs. Hasn't failed me yet! Like you said, to each their own. :beer:
  4. You ever have ANY trouble with your stuff? Do you run your lights all the time or just when you need them? Does your regulator get hot at all? I don't know WTF was wrong with mine, but it would MELT down a stator in a couple days of riding. All spark would just go away and when I would pull the stator the coils on the spark and charging circuit would both be all black and burned. Happend on a stocker, a ricky stator 200watt module and one of the ones from RockyMountainATV.
  5. You should only be able to spin them and slide them straight over side to side. If they "wiggle" I would scrap the tranny and buy a new factory one. I don't risk it with stuf that critical.
  6. Don't be afraid to slap a shit-ton of oil in there. You can never have too much oil during assembly. It will all burn off in a few seconds any way. I coat the hell out of my junk any time I tear it down. I use about a cap-full of oil on each cylinder/piston/skirt/rings each time I pull the jugs off.
  7. I know your talking about me there cracka! We need to race again now that we are both tuned and see how it turns out. I also have some different pipes now! LOL We def. need to race again though, because this story is bugging me. HA Ha Ha HA Are you going to walden this weekend for the 4th??? If you are I will be down there. Heading down tomarrow! Call me man!
  8. I just run string on mine. Forget the chain all together and just use the string you are measuring with. Works WAY better in sand. ::
  9. Just make your own man, WAY cheaper and its a simple little thing to do. http://www.dunereview.com/forums/index.php?showtopic=3476 I just blow down where my spark plugs go and listen for leaks. ::
  10. I gave someone some step by step pictures on how to do it, was that you? You have instructions right there man...
  11. I generally don't agree with brooke, but I do think she is right on with this one. :beer:
  12. I saw a thing on him somewhere, I guess most of his crap like that is actually done with video editing. He will jump it and land, then they go in and just edit him out of the picture later. I don't know if its true or not, just something I heard. I know he does some cool stuff though.
  13. Try putting some petrolium jelly around your plugs. Also, check out this post over on DuneReview. Guy made his own tester and it works good. http://www.dunereview.com/forums/index.php?showtopic=3476
  14. I did a DC conversion a while back and it caused nothing but nightmares. I have an eletronics degree and know what I'm doing too! Got a 250watt stator from RMATV already wired for it, got a ricky stator 200watt unit and did the conversion on it. Had the voltage regulator and everything. I burned up 3 stators with that shit. I will never do it again. Get some good bulbs, a bigger stator and run them on the stock wiring harness. I've talked to 3 people who did the DC conversion and all of them said it would burn up a stator in a matter of weeks. Same thing happened to me. Lesson learned, money down the drain. The only thing the battery really lets you do is run them full wattage even when the bike is off. Plus it will give you a little more power. The stator is then used to charge the battery when the bike runs.
  15. Bump, someone needs some bling!
  16. The cub is worth it once you get it tuned. I won't ever go back to stock cylinders. Everything I build from now on will have them. Cubs or a Cheetah.
  17. Send them to [email protected] and I can post them up for you. Send them to me full-size and I can re-size them for you.
  18. She can park in handicap cause she is always broken. No, really, I'm serious.
  19. Pics? Also, do you have the dyno sheet?
  20. check out... I think its called emachineshop.com or something like that. you deisng it, they make it and send it to you.
  21. Look forward to seeing how it runs.
  22. Agreed, make it a huge ball of radioactive glass.
  23. Right from an eletricians mouth right there! You beat me to this one.
  24. Do you have a set of GRR pipes to run on it? I'd try like hell to find a set and run them just to chance getting a free port job. LOL
