liquedfire
Everything posted by liquedfire
  1. top end is brand new i did a chop test and the plugs are mint im runnin 30:1 yamaha lube 2R high octane i live in ottawa but i dono how high i am LOL everything is stock but what my sig says if u need 2 know anything eles let me know
  2. just phone your yamaha dealer and get the timeing marks right on thats what i would do
  3. u got any pics of it yet????????? id like 2 see it
  4. well i burnt about a takn of gas so far and was wondering cold it will start on the 3rd kick every time run mint as i took it out today for about an hour it an fine but as i pulled into the yard and shut it off and tried 2 start it again it wouldent fire i pulled the choke out and it fired and died (lol on the 3rd kick again) then i kicked it without the choke on and it started and ran mint (purrd like a kitten) just was wondering what could cause this hard 2 start problem any help would be awsom thanks :baseball_bat: Glenn
  5. ok dude do a compression test!!!!!!! then when u do the test then come back on to this thred and tell us how much u have :baseball_bat:
  6. well 0.1886 for me :shrug:
  7. when a 4 stroke backfires that means its overloading with fuel thus meaning valves maby your vlave need 2 be adjusted try this it might help :ninja: Glenn
  8. i would put the key somewhere eles on my 87 i put the key in the front plastic right below the tank cover worked awsom and was out of the way hope this helps :ninja: Glenn
  9. if you are a new rider lol start with 1. Pipes 2.Reeds 3.Air filter and mod your air box lid thats a good way 2 start welcom 2 the HQ
  10. well im no pro but............ heres what i would do 1. Air filter (k&N air filter) 2.Shocks (works or elka) 3.set of rear tires (razor or holeshots 20") and if u go the money a set of pipes (fmf or Dg or what ever is a good deal on ebay :baseball_w00t: ) thats about all i can think of p.s and a cub
  11. hmmmmmm haveint herd of it tell now but i will be looking into this set up 4 mil :beer: could you throw a link up plz thankz
  12. well what about the tors????? and also u might have a bad coil/cdi it might be breaking down under load hope this helps :ninja: Glenn
  13. yup both pistons are at 175 psi and both carbs are opening at the same time float levels are the same lol i dono relly
  14. wishes he could afford butter
  15. well i took y carbs and my pipes off 2 do a crank case pressure test and the bottom end held 6psi for 6min Seals are good could it be float hight?????? thanks for the help
  16. nope i just milled the head and put a fresh set of pistons i left the piston clearence at .0024 and it only like over 100 octane thanks for the help Glenn
  17. my bike is smoking more on the right side as to the left side it runs GREAT but just wondering if this is normal thanks Glenn
  18. my shee is runnin at 175 psi?? i know stock it should be around 120 but shit 175 to much??? :shoothead: just askin thanks glenn
  19. well a shee should only run on atlesed 100 psi compression so there is yuor problem when u rev it up the left side catches up wit the right and starts 2 burn the fuel so put a new set of pistons and rings and give it a bore
  20. if i were you i wouldent run the 2 filters id stick wit you air bow its good 2 have when u goin in water and iv had 2 motors explode wit the fuckin filters just my 2 cents :ninja: Glenn
  21. k so i got 270 in it now and the plug is white (lean) so i was wondering how much bigger i need 2 go?????
  22. meh ill stick 2 my rubber band :shrug: cheaper and works great
  23. what i did was take a thck rubber band andwrap it around where the kick start meets the thinggy that is splind it works awsom no more rattleing for me and cost nothing hope this helps :ninja: Glenn
  24. lol thanks for all the help it turns out 2 be a mouse nest in the right front pipe L:OLOLOL but holy shit does it go thanks for all the help and glad 2 have a screemer again p.s Dg pipes work relly relly relly welll lol great throttal responce ill take a video its amazing ( 2 me it is thanks again) next project...... how 2 get 2 dunefest?????? :beer: Glenn
  25. i will try that in about an hour thanks for the help ill let you know how it works out P.S lol sorry for the double post :baseball_innocent:
