liquedfire
Everything posted by liquedfire
  1. if u check out my photos i got a set of slasher front tires and a set of kenda dominator rear tires for under $250 they work relly relly well for wood and pretty good for mud click on my link for some photos http://www.bikepics.com/pictures/628679/
  2. 30:1 on 94 octane wit yamaha lube 2r here
  3. LOLOLOLOLOL thats all i got 2 say :baseball_innocent:
  4. i think a raptor is a good shitkicking quad (back up bike lol) u can beat it and as long as u do the oil changes it will never die and as for the tippy part it cant be any worse then a tri-z 3wheeler all u gotta do is get used 2 riding it and its alot cheaper on gaz then a banshee once u got a shee and a craptor u got best of both worlds ( of corse the shee is still king ) if it was a good deal i would jump all over a craptor lol my back up bike is a 01 400ex and its come in handy more times then one Glenn :beer:
  5. well i was wondering if the yfz 450 shocks will fit a shee i tryed looking for a thred but couldent find one so any info would be good p.s my 100 post yehaaaaa
  6. well i got a complet bottom end for $250 canadian and i got 2 .050 over jugs for $50 canadian ( lucky me lol) so im gonna make a quick motor just 2 use the poor bike LOL but untilo i get the motor together im still gonna :baseball_wibble: like a girl and i plan on makein a cub ( maby) if i can afford it over the winter ( chrome everything LOL)
  7. lol i just got mine 2 work read this thred it will tell u how 2 do it http://www.bansheehq.com/forums/index.php?showtopic=63726 hope this helps :ninja: Glenn
  8. well i get my pipes my silincers my new carbs and boost bottle off of ebay i put some oil in the bottom end (because the head was off at the machine shop being shaved) i put a new .025 over top end in the meantime i put my new clutch in it my new water pump prop and other dodads i get the head back put it all back together and for got about the oil in the bottom end kick it a few times it fires it hyro locks and bends a rod so i pull it back apart ( lucky for me i work for a machine shop ) i had the cylinder crack tested and it turns out the rod bent cracked the new piston cracked the sleve and cracked the casting of the cylinder!!! so now im back 2 stage one never again will i ever forget about the oil in the crank case :baseball_wibble: short story but i figerd i would share
  9. well first thing is first get yourself a test light check 2 see if theres power comming out of the bottom end if there is then check to see if theres power getting 2 your resistor (cant spell lol) and if theres power there then check 2 see if there power at your light switch if theres power then check 2 see if theres power at your light socket if theres power there check all your grounds then check your ground that runs from your motor( the black wire comming from your bottom end) to the frame hope this helps :ninja: Glenn
  10. i think a good all around pipe would be fmf fattys up front and power core2 silincers with a k@n air filter and no air box lid and boost bottle will relly wake up your banshee
  11. well hmm that suckes eh (just came in today) lol well ill use them for like 50 hours then change them 2 wiseco by fall apart u mean like little tiny pices falling off?????????? :shoothead:
  12. im looking for a tranny for my car i need a 4 speed tranny I.E (m10, m21, rockcrusher) no rush but any feed back would be awsom thanks Glenn
  13. lol i know thanks anyway
  14. no no i know its huge but i dono how 2 scale it down any help would be good thanks
  15. lol i know i was thinking the same thing but i dono how?????? if u could help plz do lol
  16. thanks dude got it 2 work hope your kicker turns our good post some pics when your done :beer:
  17. well the screw closeist to where the air box pluges on it the air fuel mixture screw if u were messing wit it then that is your problem screw the screw in all the way and back it out 1 and a half turns then try it the screw in the middle of the carbs in the idel screw play wit that after u get it runnin good again hope this helps :ninja: Glenn
  18. i have a good friend working the part counter at a dealer i got all the top ene kit ie(wristpin,gaskets,bearings,c-clips,pistons,rings,) for $230 canadian they wanted $95 a piston for wisco lol so i said meh might as well try yamaha pistons
  19. sure it is take a very very fine sand paper and snad the kick start down then take some poshing compound ( i relly like Mothers) and rub away until u like the shink then make sure theres no oil on the kick starter and then clear coat it 2 keep it from rusting hope this helps p.s how do u get your phot from bike pics to show up where your signature would go???
  20. i orderd a set of .050 over yamaha pistons and was wondering if these pistons are any good i normaly get wisco pro lites thanks Glenn :beer:
  21. any1 on here know of any tracks around ottawa distance isint a real issue thanks for the help :beer: Glenn
  22. hey kool man im setting my shee up for this kinda race been wanting 2 try it for a while where does this take place??? my buddy has a cottage at lack simon and im always around vtt quadpro up by St jerome any info would be awsom thanks Glenn
  23. good job man glade it worked lol there pretty expencive 2 replace
  24. well thats not 2 abd at all should work keep me posted :beer:
  25. take a tie rod end splitter and hit it hard shoud do the trick
