FireHead
Everything posted by FireHead
  1. I did the same thing........... :ermm:
  2. I want a refund for my personal time I used to read this.
  3. That's pretty much accurate.......... Which usually isn't a realm threads like these have ventured into in the past on here. :biggrin:
  4. I wouldn't worry about it at all. It's not going to hurt anything. Without reading the article, I suspect the boat owners are probably worked up over misinformation as well. The premature wear and poor running condition is bogus. :geek:
  5. You can get a reasonable deal on a swingarm from Cascade. You would have a really hard time breaking one of theirs. :thumbsup:
  6. I think I have a couple of them as well.........
  7. The Galfer rotors from RMATV are pretty swell. :geek:
  8. .............beat me to it dammit! :biggrin:
  9. Can you order that stuff online or do you have to call Jeff? :geek:
  10. Your rating is 4. :biggrin:
  11. ....................Bansh-eman's left testicle? :ermm:
  12. Unless you have a bad spark plug or spark plug wire, then yes it is not iginition related. :thumbsup:
  13. Since when does BigRed hat the BansheeHQ?
  14. That's some nice work there. :thumbsup:
  15. Like I said, Each time the coil fires it fires both plugs. This is a called a waste spark style ignition. :geek: The CDI has no idea that there are even two cylinders on the bike. All it sees is on crank position and the duration between seeing that crank position. :geek:
  16. I have the following up on eBay right now: *Stator Cover *Intake Manifold *Radiator *Inner Clutch Hub *Set of bored OEM carbs with filters and cables. http://motors.search.ebay.com/_W0QQsassZfirehead696969
  17. That sounds about right. :thumbsup:
  18. No. Each time the coil fires, it fires both plugs. Unless you have a bad plug or wire, spark will be going to both cylinders. :geek:
  19. Wow! I have bever seen that before.
  20. They are the later designed hubs............ However, I think the failures were more on the 450 hubs than the Banshee hubs. :geek:
  21. Get a Nology. :thumbsup:
  22. Harkor Engineering :thumbsup:
