No Limit Powersports
HQ Site Sponsor!
Everything posted by No Limit Powersports
  1. 300 + shipping for the pair... worked perfect on a 350 drag port stock cylinder and a 350 cub
  2. Greg cuts all my trannys for us and let me tell you we have beat the snot out of them for over 2 years now with over 30 trannys out there and only 1 came back with a broken shift fork and it may or may not of been the trannys fault and that was after 2 years on the same tranny. With the way my customers ride these trannys and the way they have been holding up i see no advantage to a stock tranny over these duneables. You can rip like normal, downshift, whatever and they just keep on ticking.
  3. We have had excellent luck with ours for over 2 years. We have 1-5 duneables on the shelf... Andy M&M
  4. Your right they did seem a little high so i lowered them some but they should be right in line with everybody elses. Thanks man, havent heard from you in a while hows things going up ur way?
  5. Check out our new rear master cylinder covers. Made entirely in house will also available in flames ill get the flame picture up tomorrow hopefully... http://www.mmatvonline.com/product_info.ph...products_id=318 Ive also added a ton of product to the site for banshees and lots of others still adding everyday so keep checking back. If there is anything you need that you need and dont see dont hesitate to call me. Andy M&M ATV 877 301-1700
  6. It would probably work fine but studs are always better. You get more thread in the motor before tq so you have less of a chance of pulling the threads on the cylinder. Plus you will get a more acurate tq reading from a nut rather than a bolt. So to answer your question will it work yes but my question is why studs are not that expensive especially if you pull a thread and have to heli coil or time cert.
  7. Well first things first you need to check to see if you got spark? Then we can go from there
  8. Ive got the stock keys and the timing plates give us a call we will hook ya up M&M ATV
  9. Just curious if anybody had some extra room or something come up and they couldnt go and didnt need there spot. I need enough room for a truck and toyhauler in south camp for a few nights, I would be more than willing to pay for the spot. I had a buddy drive out today and couldnt get anything. I really need a spot in south camp because all the alky bikes cant make it across the dunes for racing and back without running out. Any help would be appreciated thanks, Andy
  10. Ive built bikes that have been running on AV gas for upwards of 5 years flawlessly, never had any problem with it plus its cheaper round $4.00 instead of $6-$7 for race fuel. Not sayin its the best but it will work and work good.
  11. Assuming that your old cylinders were .100 over and your new cylinders are 64mm and you didnt change the domes size this could be the route of your problems. With the new cylinders being smaller you will have a smaller combustion area and more compression also did your old cylinders have any porting done to them? This would cause lower compression before and allow you to run this setup with pump gas. Right now you are way over the limit of safely running pump gas with your compression/timing combo. Sounds like to me and this is just my $.02 that you just have to much compression and timing for pump gas, keep in mind that there are many different varibles that can effect your compression like bore size, porting, squish, base gaskets, and how fresh the motor is just to name a few. This may be why you were okay before and not now, try lowering the compression by putting in a larger size dome and i would also consider getting the dome custom cut to fit your motor cause it sounds like your squish is a tad loose or you might try a thinner base gasket if available. Just my $.02 Andy M&M ATV
  12. Actually i think there is now its just across and down the road from where jims used to be...
  13. still got the mikunis and the lectrons everything else sold
  14. still have the lectrons, mikunis and the transmission
  15. How much for the cases
  16. 28's sold Still have the lectrons, mikunis and the override
  17. I have a set of small bore in frame chrome drag pipes for sale used 1 season very little excellent shape like new. Will have pics up tomorrow $450 + shipping
