J-Madd
    19
Everything posted by J-Madd
  1. Could be at the chromer. Mine were bare. And non stamped so that makes sense.
  2. Like I said before also, I got a set for a Scimitar in about 2 weeks. A far less common pipe than DM.
  3. Assuming that the clearance is due to the step in the domes and not a negative deck height (piston in the hole at TDC) you can probably use fine sand paper and a piece of glass or marble and shorten the step on the domes. If it's negative deck though there may not be enough step there to take it down another 0.01" or so. It the step is too small the oring won't stay on during installation.
  4. The head should be ok. Make sure there isn't any metal or porcelain embedded in the head. A good used stocker is cheap enough, though, that I'd just replace it.
  5. You can use silicone on the studs and get away with the open flange nuts as long as you're not bottoming out the nut on the unthreaded shank of the stud.
  6. Lol!!!
  7. HP/CC is always gonna be better with smaller displacement if both builds are maxed out. Not disagreeing that most cheetahs don't run as good as Cubs.
  8. What a steal. That (and any new big motor) will be a nightmare to get dialed in.
  9. Sounds like slides in backwards. You say it eventually takes off. If it was electrical or some other issue that would t happen usually.
  10. He was kidding about that.
  11. You might see if Precision Powersports in Imperial has a used oem stator they would sell.
  12. Sounds lean on the pilot or air leak. I don't know mikunis so I don't know if that jet sounds right or not. Are you using the choke?
  13. Lmfao
  14. Those were like gold a few years ago.
  15. Not a problem. I run non resistor if possible, but it probably makes no difference.
  16. Pismo Beach, Maine FTW
  17. I like the red white and green flag. Hard to tell what country though.
  18. 250lb rider won't outrun stockish banshees with 180 lb rider. 12/40?? 8 pdl?????GTFOOH. Entertaining though.
  19. Lots of kart racing sites have them pretty cheap.
  20. I have some for sale in 82 RO Kevlar. $350 for OP only.
  21. You can't be serious.
  22. Don't know if there's a second page to that or not, but 2 of my bikes are missing.
