NEVER SATISFIED
Everything posted by NEVER SATISFIED
  1. THINK WE'D REALLY LIKE A PIC OF IT... BUT ARE YOU WANTING THE WHOLE SLIDE TO BE COMPLETELY SHUT MAKING WHERE THE BOTTOM OF THE SLIDE TOUCHES THE BOTTOM OF THE CARB?
  2. i think your better off sellin that or something and milling your stock head.
  3. to hone is just cleaning the cylinders up.. when you bore it your shaving and honing (cleaning) the cylinders... gotta ask yourself how long has it been since you've redid the top end, has your bike ran to spec in that time, do i have low compression. if you dont want to spend the money then get a hone job. are you on stock pistons? i did a hone job just cuz i ride hard and just needed a good cleaning... bought me some new rings.. got a hone jobb and i was off.. runs like a champ! although i dont know how many times you can hone a cylinder before it needs a larger size piston.
  4. SWEEEEEET!!!! I'LL CHANGE THE PILOTS FRIDAY WHEN I GET THEM AND REPORT BACK... SO FAR IT RUNS REALLY WELL BUT YES IT DOES SEEM RESTRICTED ON BOTTOM END.... ALSO I AM RUNNIN OCTANE BOOST AND NOT RACE GAS... GOTTA GET A NEW GAS CAN AND SPEND SOME CASH.. EEEEK!!!
  5. IN KNOW MY WHEN MY GYRO X9000 IS FLIPPIN OUT THEN IN THE DUNES I FLIP MY PADDLES AROUND AND GIVE ER SOME GAS AND NO PROB IM HEADED IN REVERSE..
  6. GOTTA GET 8X8 RIMS.... STOCKS I BELIEVE ARE 9 WIDE... WHICH WILL GIVE YOU NO SIDEWALL FLEX GOING INTO A TURN CAUSING SEPERATION OF BEAD... NOT GOOD...
  7. shit.!!! i did forget to grease the mofos... thanks man... that wouldnt have been cool for them to stick... haha... hey trav.. any ideas on rough idle or the fact i have to keep thumbing the throttle when i fire it up.. air screw or pilot poss?
  8. i believe once you get over the 155 range.. 160 is def race or AV gas mix 50/50
  9. WHAT SEEMS TO WORK FOR ME IT TO DO A MOTOR SWIVEL MOUNT GYRO X9000... REALLY SIMPLE.. IN A PUSH OF A BUTTONT HE MOTOR WILL TURN 180 DEGREES BUT WATCH OUT FOR THE PIPES SPECIALLY IF YOU HAVE DRAG PIPES THEY WILL BURN YOUR LEG. SOON AS THAT MOTOR IS COMPLETELY 180 YOUR READY TO RELEASE THE BUTTON AND OFF YA GO INTO REVERSE... ... ONLY PROBLEM I HAVE FOUND SO FAR IS IN THE X9000 MODEL THE BUTTON GETS STUCK AND THE MOTOR WILL KEEP DOIN 360'S IN YOUR FRAME AND THAT CAUSES YOU TO SPIN CIRCLES RAPIDLY. I'VE GOTTEN DIZZZZZY AND WELLLL
  10. REALLY? TO BIG ON THE MAINS... HRMMM...!!! WHATCHA THINKIN.. I HAVE A 300...THATS IT.. NOTHING IN BETWEEN I WENT TO THE 2ND CLIP CUZ V FORCE 3'S MAKE IT RUN MORE RICH... I CONSULTED THE CARB THEORY CARB THEORY IN THERE IT SAID... QUOTE: Reeds Add Reeds, Aftermarket reed cage, or Ported reed cage:Move needle clip one position leaner, adjust airscrews, 0-2 sizes larger on the pilots UN QUOTE. FEEDBACK?
  11. ALRIGHT IM A IDIOT~ ONE CARB WAS STUCK ON WOT.... NOW IT RUNS LIKE A FKN CHAMP!!! THANKS FOR EVERYONES HELP!!! NOW TO DIAL IN THE JETS.. FUN FUN
  12. YEAH I HAVE PC PIPES..... OK.. OK... WELL HERE'S THE F'N KICKER... WENT AND GOT NEW PLUGS.. INSTALLED THEM MOVED MY NEEDLE UP TO 2ND FROM STUB... ALL IN THE PROCESS OF TAKIN MY PODS OFF FOUND THAT ONE F'N CARB WAS STUCK WOT ON THE SLIDE ... THATS WHY IT RAN WOT WHEN I KICKED IT OVER... TURNS OUT THE GROOVE AND THE NEEDLE DIDNT SIT IN RIGHT..... ....... SO ADJUSTED EVERYTHING.. PUT IT ALL BACK TOGETHER AND THE MOFO FIRED RIGHT UP... ALTHOUGH NOW IT DOESNT WANT TO IDLE THINK I WILL ADJUST THE AIRSCREW IN .5 TURN SINCE I AM 2 TURNS OUT SO BASICALLY WE ARE UP AN RUNNIN!!! NOW WE ARE AT 500 SEA LEVEL RUNNIN 110 OCTANE NEEDLE AT 2ND CLIP 320 MAINS.. STOCK PILOT... AND RUNNNNNNNIN...
  13. here's what david noss from noss machined heads told me... QUOTE FROM THE MAN HIMSELF: At Little Sahara, you would be okay with 20cc domes as long as you don't advance your timing. At Glamis you would need to run 50/50 or 100LL Av Gas. Around Dallas, you would be borderline with premium pump. You could check your compression after installation and see if it is above 155. The price difference between premium pump gas and the 100LL isn't very much around here, about 20 cents per gallon. It has the octane, lead, and stores for a long time without going sour. If you installed 21cc domes you would be okay with premium pump at any elevation but wouldn't gain quite as much performance. LIL SAHARA IS ABOUT 800 ABOVE SEA AND DALLAS IS ROUND 500.. GLAMIS IS ROUND 1000' ABOVE.. HOPE THIS HELPS
  14. yea... but if you have some spare gas runnin around... throw in a gallon into your mix.... just for future reference... may foul out a plug later on..but you will come within 1 size on the main and thats pretty close...
  15. CHECKED IT.... STILL CONNECTED.. JUST WENT AND GOT ME SOME NEW HIGH PERFORMANCE PLUGS... MAYBE I F'D UP THE OTHERS WHEN IT STARTED AND WENT WAAAAAAAAAAAAAAAAAAAAAAAAAAAA! 3 TIMES MAYBE I FOULED SOMETHING...
  16. WELL I PUT ON A V FORCE 3...A NOSS 19CC...CHANGED MAIN FROM 220 TO 320 KEPT PILOT STOCK.. CHANGED THE NEEDLE FROM STOCK TO 4TH CLIP AIRSCREW 1.5 OUT ... AND ADDED POD FILTERS AND DID AWAY WITH AIR BOX...
  17. dont forget to mix properly... 32:1 is rich enough im at 40:1 at sea level
  18. IM JUST ABOUT THE SAME BORED 65.5 PORTED MILD V FORCE 3 NOSS HEAD 19CC STOCK CARBS WITH 320 MAIN STOCK PILOT... NEEDLE 4TH CLIP (THINK ITS WAY TO RICH HERE AND I NEED TO MOVE IT UP TO 2ND CLIP SINCE THE V FORCE RICHENS THE CYLINDERS) KN POD FILTERS ... ALTHOUGH MINE WONT KICK OVER ANYMORE SINCE I CHANGED ALL THAT AT THE SAME TIME SO IM IN MY TROUBLE SHOOTING ERA... BOUGHT 30 PILOT HAVENT INSTALLED IT... AND HAVENT PUT NEEDLE IN 2ND CLIP YET.. SO GIVE YA AND IDEA WTF WILL HAPPEN...IT KICKED OVER AND RAN LIKE WOT SO I KILLED IT THEN I KICKED IT 3 MORE TIMES AND THE SAME THING.. NOW IT WONT START.. SO ....LOL
  19. IF THE CARBS ARE TO RICH.. I.E THE NEEDLE TO RICH AND AIRSCREW IN TOO FAR CAUSE A BIKE NOT TO KICK OVER.. DID SOME MODS AND ADJUSTED THE CARB AND IT FIRED UP SCREAMIN LIKE IT WAS WOT 3 TIMES THEN I KILLED IT AND NOW IT WONT START.
  20. THINK THATS THE ONLY SETUP COMBO HE HASNT TRIED YET... GO FOR IT MAN... BEEN EVERYWHERE ELSE!!
  21. ATLEAST IT WILL GET ME CLOWER TO DIALING IT IN... STILL DONT KNOW WHY IT WAS WOT WHEN I STARTED IT 3 TIMES IN A ROW.. THEN I TAPPED ON THE FLOATS AND THEY GOT UNSTUCK THEN THE DAM THING DIDNT EVEN WAT TO START... GUESS I 'LL PICK UP A CHIT LOAD OF PLUGS AND GO TO CHOPPIN.. GOTTA GET ER RUNNIN THOUGH FIRST...
  22. IM GOING TO HAVE TO SAY NO... SEEIN THAT YOUR ELEVATION IS ROUND 100 FEET ABOVE SEA, IF YOU LIVE IN NY-NY AND THAT YOU HAVE A TIMING ADVANCE. IM AT 500 ABOVE SEA WITHA 19CC NOSS AND I RUN RACE AND I HAVE NO DEGREE KEY. THATS WHAT DAVID AT NOSS HEAD SAID I HAD TO DO. SO...
  23. . .. .. ANYONE ELSE THINK THIS IS KINDA RICH.. IF THIS IS THE CASE THEN 320'S AND 340'S ARE TO HIGH AND NEEDLE CLIP DOESNT NEED TO BE MOVED.. WHOA! IM RUNNIN 320'S WITH POD FILTERS (NO BOX), V FORCE 3, STOCK CARBS, 30 PILOT, CLIP ON 2ND FROM TOP AND 40:1
  24. DID YOU TELL US YOUR FUEL MIXTURE?
  25. i used a saw to cut off the rubber and then used the dremmel to clean up excess crap.. man if you have some freggin 30 pilots.. that would be awesome ... i have called 5 dealerships around here and they are all on the 7-10 day band wagon. i only have this weekend to get er ready for the dunes on easter weekend.. im booked up on workin on the shee till the dunes hit and there isnt anything worse then being out on a trip and having to work on a bike
