mrandersontheone
mrandersontheone's Achievements
  1. Don't worry dude...that isn't how most of us feel. Thanks for what you are doing over there. I'm sure that guy will get taken care of......pretty stupid to go on there and give his name like that.
  2. Sweet....thats what i'm thinking about getting. So i assum your pretty pleased with it?
  3. Hey Timmy, what kind of porting did you get done?
  4. White brothers has a kit. Actually its two kits, One is the throttle cables with the carb caps and the other is the idle screws with the drill bit needed.
  5. Go to an auto parts store and get a pickle fork. Should run you $5-$10.
  6. Hey Push, are your elkas zero preload? I test rode the Shee with the new springs and you were right. I felt the pogo effect. I guess i'll try adjusting the rebound.
  7. I don't have the yfz shocks but i am having trouble getting the camber right on mine. The camber is too negative even with the setting at its max.
  8. Did any of you guys have trouble getting the camber set up on these? I have been fighting with this thing for a few days now. The camber is too negative on one side even with the adjustment maxed out. I can't figure it out.
  9. They are zero preload. I hope with some adjustment i can get it to work. Can't really afford a new rear or revalving right now.
  10. Anyone running elkas with stock rears? I just got some front elkas put on but haven't had the chance to try them out yet. I was wondering if the stock rear shock is decent. Im not an expert rider but want to start jumping the Shee at the local mx track and i want to be sure my setup is gonna be okay.
  11. From what i understand they are good for trails. Mostly a low and mid range pipe.
  12. Sweet...thanks for the info.
  13. What is the advantage of having the delron bushings?
  14. I just received my procomp suspension a-arms with elkas. Problem is that the a-arms don't have any zerk fittings! According to the website it is supposed to come with them....AAAAAAAAAHHHHHHHHHH! Sorry just had to vent. Anyone else have this problem. I have ordered from Alba before and haven't had any problems with them. Now i have to wait till Monday to call them and i can't ride tomorrow.
  15. Kawasaki gay green. That will get some attention i promise.
