SyNtAxx
Everything posted by SyNtAxx
  1. Hello, I have Jims MX port Job and i love it.....However i dont think it would be fair to give away his pricing. Give him a call and he will taylor a port job for your needs.... he is a great guy...you wont be dissappointed. Nick
  2. hello, It was my understanding that Power steering fluid and transmission fluid were the same. i never substitute anything....just get teh right stuff...then you dont have to worry.... Nick
  3. Hello, Well its not a banshee but its my spare wheeler for my girl to ride. She hasnt been bestowed the honor of the banshee yet I need: Rear disk rotor. A working stator... Any help would be great.... Thanx Nick
  4. hello, I'll take a few...and proudly display......... Very Nice Nick Passion MxPort
  5. HEY, my mistake i missed the part in his original post where he said it melted down. I agree...if metal was down there .....split the cases..... Sorry about that... Nick
  6. Hello, When i redid my topend.... I cleaned out the bottom end too... here is what i did...this may sound retarded but it worked for me... i sprayed a shit load of carb cleaner in there.... Then i tore up pices of terrry cloth and stuffed them in to the lower end..and rotated the crank a round....and the terry cloth pulled all the loose dirt and git out.. then give it a final wash down with premix if you like....and you should be good.... *Disclaimer*....Syntaxx is not responsible for anybody blown or welded cranks..and or any subsequent damage as a result of anything that I have said... Nick
  7. hey, I jsut got a set of Razer 2's 20x11x9 from magic racing on douglas 190's they were in stock nick
  8. hello all, The bike starts......thats not the problem....sorry for the confusion... Its just since I replaced the air screws the idle is not the same...i figured that is because the older screws may have been worn..... So I may just have to adjsut the idle... yes/no ? My real concern was this...: After i resynched the carbs....I ran the bike and sprayed carb cleaner around the carbs and intakes bling bottle etc.... With the carb cleaner the engine reved higher......(was this because carb cleaner is almost like ether and a very thin gas and would penetrate even the slightest crack or was it cuz it got sucked into the airbox.....i tired to cover the air box as best I could... THEN....I did the same test with wd-40 and spryed it all up while the bike was running...and it DID NOT raise the rpms of the engine......my only thought on this was because the wd-40 is heavier and may not penetrate an "air tight" seal or slight crack in rubber... Thanks again everybody....for your input... So my question is still this...Do I have an airleak or not ? Nick
  9. Hey, how bout a Glock full auto handgun... the local 5.0 uses them round here......get it round....no pun Nick
  10. Why wouyld I want to use ether ? the carb cleaner raises the rpms.... but the wd-40 does not..... so is there an air leak or not ? Nick
  11. Hey all, I just changed my airscrew on my carbs because the slots on the top were rounded off...... i reset the airscrews to 2.5 turn out just as before Now ever since then the idle is off...doesnt seem to want to stay running..... I presume new the airscrew settings are prolly not going to be the exact smae as the others were.... Oh....I sprayed around the carbs with carb cleaner while the moter was running...and it started to run faster....this is an indication of an airleak righ.... But whan i repeated the same test with wd-40 the engine rpms stayed the same and did not elevate...so which results do I beleive? the carb cleaner or the Wd-40? I think the carb cleaner is almost liek ether and would raise the rpms regardless because the gas is so thin yes/no? I didnt see any big cracks in the intake boots or anything....I dunno what to do now Please advise.... Thanks Nick....
  12. Hey all, I just broke the tip off my needle jet They are stock needle jets for a 95 banshee? Does anybody have any for sale? Should I replace both at the same time? Or should I use after market needles.....? Goto dealer ? Nick
  13. Hello, Wow....so you want me to lean out the needle? Leaner than stock? Can yuo explain to me why?.... Please dont mis understand...I am not questioning your advice...just curious how/why you think leaning the needles is the way to go.... I am by no means an engine/jetting master. Thanks again.... Nick
  14. Hey, My plugs are charcoal grey.. i guess i will have to put in a new set of plugs and try again
  15. Hey all, Well i am expecting weather around 70 degress this weekend here in PA. I was jetted for march at 360/30 and it seemed to run ok for temps around 45-50. I just rode the bike today...temp was about 60 degrees today and it seemed like it was sputtering and carrying on just about all over the throttle range. I would think the mix would get my richer because the weather is getting warmer correct? So i must jet down now correct? I didnt run the bike for about 3 weeks...but i doubt the carbs gummed up that quick? I run Klotz supertechniplate(Castor). I am jetted at 360/30 needles at stock location...should I jet down now? i just dont want to toast my new topend and porting...see sig below for complete mod list. I pulled the choak while I was riding and it seemd to almost shut the engine down...so I imagine i am just running rich the way I am jetted now? Please suggest what I should do..... Thanks a bunch in advance... Nick
  16. Hey all, Well i am expecting weather around 70 degress this weekend here in PA. I was jetted for march at 360/30 and it seemed to run ok for temps around 45-50. I just rode the bike today...temp was about 60 degrees today and it seemed like it was sputtering and carrying on just about all over the throttle range. I would think the mix would get my richer because the weather is getting warmer correct? So i must jet down now correct? I didnt run the bike for about 3 weeks...but i doubt the carbs gummed up that quick? I run Klotz supertechniplate(Castor). I am jetted at 360/30 needles at stock location...should I jet down now? i just dont want to toast my new topend and porting...see sig below for complete mod list. I pulled the choak while I was riding and it seemd to almost shut the engine down...so I imagine i am just running rich the way I am jetted now? Please suggest what I should do..... Thanks a bunch in advance... Nick
  17. hello all, I am in need of some new rear tires for my Shee. i was considering Bandit XC or Maxiz razer II's I was wondering if any of you have experience with either tire. i would like opionions please. i ride all terrrains...from leisurly trails to bad assed hill climbs in the "strippins" Thanks for your help.... Nick
  18. Hey, If it was me....(which it was back in Feb...I had him port my jugs..) i would send it all to him. Partial assembly will only cause more pain... Send it all to him and assemble all at once.... just my opinion.... Nick
  19. Hey, If you callin vitos...may as well gewt prices on his 240 kit....its supposed to be pretty good they say? Nick
  20. Hello all, How will lightening my flywheel go with my ported engine. Will it be good for hill climbs? My mods are in my sig. Nick
  21. Hey, In my opinion there is no "best" setting so to speak. As I am sure your aware that anytime you adust the amount of airflow in/out of a banshee you need to rejet. You want took look for a copy of the jetting FAQ on this site. Extremely valuble. It will explain everything you need to know about jetting. Jetting is dependant on elevation also. Have you done a plug chop on fresh plugs to verify your mains? I am no jetting expert...but i have done my fair share of tearing carbs apart. Find a copy of the FAQ read....then start from there. Whats your mix ratio ? Nick
  22. Hello, Sounds retarded...but do you have any pics...? Nick
  23. Hey, i would check the stator.... and the stator pickups. Nick
  24. Hello, Porting will lower your compression some what depending on the port type and the amount of material that was removed from the cylinders. Nick
  25. Hey, am jetted at 30 on the pilots and 360 on the mains with my mods listed in sig.... Maybee I am way rich ? My altitude is varied from....850-1700 feet. What you think......my plugs look good...so you sound lean in my meager opinion.. Besides you can always jet leaner if your rich....but if your lean you may nnot get the chance to jet up if you catch my drift..... Trust your gut....and go rich and work your way down... More than likely those jets may have been just a starting point..... Nick
