cheezehead
Contact Methods
  • Website URL
    http://www.atvingmanitoba.com
  • ICQ
    7452203
    Manitoba, Canada
    2000 Yamaha Banshee, Bills pipes, Shaved head, Ported cages, Boyseen reeds, Fox shocks
cheezehead's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. Here's what it's all got I know I
  2. hehe see would have done that again to myself
  3. Bought them off ebay not thinking and the bolt pattern's diff so I'm looking for Banshee, Warrior ot Raptor hubs to trade. Thanks.
  4. Any after market parts on it? a-arms axle? swing arm?
  5. Thats what I had in it originally but she was falling on er face when I hit 6th would loose power would rev fine but had no power in last gear when I went up it pulls like a mother
  6. Weird I replyed and it never showed up well I'll try this again mx port polish, ported cages, boyseen reeds, +3 advance, shaved head, airbox with nolid, stock carbs 380main, 27.5 pilot, around 300ft temp is around 25c outside. Thanks.
  7. Actually I should mention that I'm running the stockers the 38mm was killer on the mid and top but I lost to much on the bottom with it. as for the air leak I don't think so but will check tomorrow whats weird is that if I throw in a new set of plugs it's fine for a half day or so then it starts up again.
  8. Compression is 120psi and running regular fuel for the past few tanks.
  9. Here's the scoop I put in fresh plugs runs sweat after a couple hours if that then it starts popping out the right pipe when giving er. If I change the plugs everything is fine again I changed the seals in the pipe thinking it was leak in the pipe plugs look fine when I pull them might be to the rich side as you can see in the pic. jetting is 380main 27.5 pilot 300ft bike specs in the sig. Thanks.
  10. Acctually here's the link http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...2477970452&rd=1
  11. If you look on ebay he's usually got a set for the Banshee for like $359 or somehting like that vs. the like $500 he want's on his site
  12. traded a guy for some stuff ended up like $100 or so maybe less (Snow pro is a snowmobile Actic Cat I think) but the shocks look pretty much the same as the polaris atv to me
  13. Hmm seems that I can only post 3 pics at a time. The spacers I just used washers
  14. Yep This is when I had the stock arms Current setup Sorry for the size screwed up resizing them
