frocashmoney24
Everything posted by frocashmoney24
  1. got some pics, are do they have rezzi's and do you know the weight there set up for
  2. nyuk your always savin our ass's
  3. dont bore more then you have to, it would just be like cutting down the engine life, you dont get much power from boring, just a fresh top end, so abore to .10 and get some new pistons
  4. that would be a sweet idea, but its probably to much weight for the dragger
  5. can you take a picture of it, i wanna see it, maybe pre ignition? or to lean
  6. those shirts are hot, i might have to order one even thou im not goin
  7. yup they will, they didnt change much from 89-now and shocks wasent one of em
  8. banshee's normally smoke like mofo's, but if this is new and the smoke smells like ass its a bad gasket and cooling fluids mixin in
  9. i dont know about you, but puttin around that long would get me hungry! bring some granola bars n water, and also a tow rope! you never know
  10. i have some holeshot xct's for sale if interested, there almost brand new and they do hook up in everything
  11. well has it been siteen awhile, maybe the jets clogged or its just not startin with that old gas, try some new mix and see what happens
  12. i need some +1 tie rods will trade straight up for the brand new +2's i have, i have pics but since imagestation's not workin ill just email them to you
  13. sounds like you blew 2 paychecks! when you get her all thrown together tell us how all those mods woke her up!
  14. if ur sellin it for 450 ill buy it , but i just rebuilt my bottom end, and starting would have nothing to do with that, if it goes in 6 gears then your bottom ends fine, the crank only goes in one way so u dont have to worry about that, did you check your reeds? dump some fuel in the sparkplug hole and see if it starts, did you drain all the gas out of your carb when ou took it off?
  15. how much for a red tank cover, and a stock tank if you have one and pics
  16. then youll be allright, good luck
  17. well the reason ur plugs are fouling is the jetting is off, sounds to me that you mihgt have a bad reed or a clogged jet
  18. setup looks good, for the crank, get it trued and welded and you'll never have to worry aobut it coming apart, a mild race port n polsih would benefit you alot, and i'd look for something besides stock reeds to run to, good luck, what are you doing for suspension because we all know thats the most important part
  19. i get a pic of em rocket [email protected]
  20. i dont know wether to hate the guy, or buy a cd.....
  21. the wider you go the more expensive it gets, but its well worth the money
  22. those are both some of the sickest people living out there , but did you hear about the guy that got high on butane and cut off his toes cooked them up and ate then and when the cops arrived he asked if they wanted one
  23. yea , just bend the tab over the nut and youll never have to worry about it agian!
  24. sponser me, im tellin ya i go to alot of races where people could check out ur stuff , and im pretty handy with a comp so if you need any help just get at me
  25. the washer goes behind the nut to make sure that it doesent spin itself off,
