wesw
Everything posted by wesw
right here sounds like you have way to big of main, did you try like a 155 main and see what the plugs looked like. if its idles smooth and doesnt load up then your pilot circuit would be fine. and then take it and roll into the throttle dont mash it, if it takes off and wants to run like a streak then your needle is close you can adjust the clips up or down to see if one helps more than other. then hold it wot and do a plug chop. 162 i didnt hardly run that big of a main on my cub. that or you have the bike lean down low and need a big main to make a correct plug. hard to say with out riding the bike but i think your needle combo would work.
first off i wouldnt listen to that info each bike is different. and you jugs are ported. 290 mains are just big enough for bolt on mods basically play with you bike and ride it and see how it acts. my guess being its ported by who ever you will need 27.5 30 pilots and 320 mains + but i dont know who ported your stuff. just listen to your bike.
some dyno guys try to get a perfect air fuel curve and its not possible or shouldnt be you want a 2 stroke to go lean then it will start to get on the pipe. i had similar experience they put a huge pilot in it and if you just rode it around it would load up and wouldnt clear out very well. lower your pilot to like a 30 and then re adjust your main. and see how it runs.
jims worked over alky 4mm cub isnt hitting 137 so no way stock jugs are doing that. all dynos read differently no standard way of testing them that i know of. my old duner made 80hp on nmotions dyno at wichita with shearers it might have made 75 down in tulsa or 85 some where else who knows. theres a local guy here with a trail, hill climb 350 that claims his bike dynoed at 87hp at waynoka. 100 bucks the clutch slipped or something and it spiked the dynoe but he thinks its 87hp and its not even close. took buddys 70s hp bike and beat him pretty good and so. if jim claimed that which im sure he didnt then he is spiking his coffee to make that much on stock jugs. he can make them run good just not that good unless your going to pay for bridge ports, fully welded up everything and lot of money and time into them.
happy birthday shawn.
high def of that wouldnt be something i would really care to see lol but easy to find www.efukt.com
i think they make a 34/36 that would be a good carb for a 4mm
LECTRONS ------------------------ PROS NO jets to buy ever again. the needle controls the idle and the mid range and the powerjet is your main. i notice a bit more low end compared to pwk but talking not much but its jetted fat down low. to control the idle and blah blah you adjust the length of the needle. measure both ones with a caliper and makes sure they are the same length. CONS ------------ price they are 6 bills easy unless you find a hell of a deal. that or used the adjustments arent easy to control meaning if your bike likes a small pilot to idle but a rich mid range it hard to do with just controlling the needle now dennis can get you different needles for whatever but they arent cheap to just start swapping out. my cub likes a richer mid range but it will load up at idle so it doesnt idle the best. i have it really close it idles higher than i would like but the power delivery is nice so i just deal with it not idling the best. pwk are like others have said. cheaper but jets can be $$$ and i have a bag of jets and needles for them. $$$$$$ will say lectrons are not as cheap but if you get them adjusted they are a sweet carb little to no cable resistance wont wear your thumb out. anyways hope that helps that is for gas by the way if your running alky i would only suggest lectrons really easy to run from what ive seen.
ya ill trade porn also i guess. sounds like john has some good interracial porn already to go. but looking more like a series from hbo or someshit.
no had some on vhs but it was like the first 3 seasons.
looking to trade some complete box sets movies or shows let me know what you have i got oz all the season and other stuff. south park also
its the temp of the air coming into the motor coolant temp wont help it if its -5 below and your bike is 180 degrees its going to be really looking for fuel cause the air charge will be very dense meaning lot of oxygen. to sync watch this http://www.bansheehq.com/forums/index.php?showtopic=95025
turn your air screws in or put a bigger pilot its lean.
was told 1.85mm before tdc was +7 degrees. all depends on what your going to do and what fuel your domes blah blah talk to you builder and go from there.
there are holes where stock coil was you can mount one there, i think that was the right side, and theres a spot on the left side, i think i drilled it out to make room for a bolt to go thru. i made sure there was a good ground on both coils, you will need to wire 2 kill switchs or as you want 2 tether switches i think or wire them to kill both coils. what are you going to set your timing at in MM??
for the record an 80hp motor built right and setup right can be quite duneable. its in all how your builder sets stuff up and pipe, domes and the whole combination. the whole package
man its a free forum you can voice your opinion, the members shouldnt hold it against you for voicing your opinion. your products should stand up for themselves. anyways i love my chevy 2500 duramax.
? who gets paid 73 dollars an hour. is that some special over time holiday pay or something i dont see that. if so i really dont have any feelings for them wow thats some jack.
FIRST OFF RNBRAD IS ALIVE BUT TOO GOOD TO SHOW UP AT DUNES WITH AN OLD BUDDY HMMM??? LOL giving you shit old man. sec the cost of living in the us is more than japan so the workers get paid more. if we all looked the same as they do in japan it wouldnt matter just pay something just cant tell who its going to.
Marvin Shaw, Override, Drag Bars, Swinger
wesw replied to gregrob's topic in For Sale - Parts & Accessories
what you want for the foot pegs. -
there is a reason sprint stocks suck a dick there service is the same, they are rated as one of the lowest in customer service, and their coverage isnt nothing to brag about unless you live in a big city. read in wichita paper, spring lost like 10 million subs last quarter. yeah go team go. and buying out nextel really helped. shawn you there............................ hello........................................ blah blah................... dropped call. anyways just a rant.
the gov't has good oversight they watch out for us and make sure we dont get screwed over. those executives need some time off to relax they work hard from all the interest and other job the steal from us. come on man. its only 750million billion thats just change.
you used a fucking 16mm dm for mx riding i want to see videos of that. seen a 10mm dm run and sweet god i looked like a handful on a drag strip let alone mx racing. please post some videos.
Whats the best way to sync banshee carbs
wesw replied to ATVridinMaNiAc's topic in Banshee Repairs and Mods
http://www.mooreparts.com/store/product/474/AC000124/ is the same one jeff has. both are great tools to have or a must have item i made a youtube vid how to sync carbs up look up username wesw78. -
cant see the pic unless the person is a paying member on ps.
