Beatty89
    1996 Shee FMF Gold Series Fatty Pipes Cool Head Ported & Polished Moose Boost Bottel Racing Clutch 5+ Swingarm
Beatty89's Achievements
  1. No i didnt replace the reeds..How would i check the timing..ive never done it with a 2 stroke..Ill check the gap
  2. No i didnt replace the reeds..How would i check the timing..ive never done it with a 2 stroke..Ill check the gap
  3. Im runnin 32/1 with yamalube>>what happens if the flywheel spun
  4. Yea i forgot to add that it dose have good spark on both sides
  5. Alright guys ill start from the begining..I blew up my banshee and put a rod through the case at the begining of the summer..I finally got all my new parts last week and put it back together..before i tried to start it gas was leakin out of the overflows on both carbs>I soaked the floats in carb clean and that solved that problum..Kicked it over a couple of times and it started right up..everything sounded fine then after about a minute of runnin it died..Now it wont even fire and every now and then it makes a wierd poof almost like a back fire but not as loud..Im new to the world of Banshees and 2-strokes so if its something simple take it easy on me.. Thanks alot
  6. Thanks alot guys..
  7. Hi, I recently put a rod through my case so the banshee is in rebuild stage..Its ported and i ruined one of the cylinder jugs..Do i need to get the jug ported or will it be fine with one side ported and other side not..Ive called a couple macanics and some say it needs to be and others say the other piston will pick up the slack for the un ported side..Moneys tight and i really want to get it running..thanks Josh
