nuc_welder
Contact Methods
  • Website URL
    http://
  • ICQ
    2004, shaved head, boyesen reeds and cages, 340 main jets, pod filters, CPI inframes,and 15t sprocket
nuc_welder's Achievements
  1. I know its not a banshee, but not sure where to look. If anyone knows a site that is as helpful as this one for a yfz please let me know. K well rebuilding the top end just wanting to know if there is anything special to it, like timing or anything? Everything else seems to pretty self explainatory.
  2. Heres a conversion chart to convert from inches to mm http://www.worldwidemetric.com/metcal.htm
  3. I bought a boss intake, the boots are for a 34-36mm carb, I've got 30mm carbs now, anyone know if the vitos boots will fit and if not where can I pick up a set of boots at?
  4. Never thought bout that, prolly wouldn't hurt to check its an 02 and its never been checked.
  5. K thanks to all that replied, Finally found one today at the local hardware store, I was thinkin that it was metric, turns out its SAE, 7/8 14. Guess I should of tried both!
  6. Are you sure I thought that the g-force was a little bigger?
  7. Luck keeps gettin bad, stripped out the axle nut on my g-force axle, now I cant find one anywhere, checked parts stores, ebay, rocky mountain and still no luck. Anyone ever had to replace them, or know where to find one? It's not the lock nut, its the nut that holds the rear hub on. Need help bad ::
  8. Anyone know bout what needles need to be?
  9. What about the needle?
  10. yah its a banshee
  11. What kind of shape is the skid plate in? Can you post a pic of the under side?
  12. Ok my friends bike has a noise that kinda sounds like a collapsed lifter in a car, it has tapped for a while but not real noticable, till he had a head gasket blow out this winter, he had it replaced and now its loud. Any Idea bout what it might be? The bike still has alot of power just sounds bad.
  13. My friend has a set of 35 keihin's and needs to know where to be at on his jets. His mods are 4mill stroker with long rod, cpi inframes, vf 3 reeds, k&n pods, clean up port, stock bore. We ride in southern missouri, mainly draggin on the highway, bout 700 feet above sea level, 60 to 75 degrees, he ways bout 165. If you need more info I get it.
  14. Well I've been looking at pistons on ebay and I seen some M&H pistons on there half the price of wiseco. Anyone run these before or know if they're any good?
  15. Ok well I mic'd my cylinders today, they measured 2.545" which converts to 64.643mm, so I would need to buy a set of 64.50 pistons right, if not what size do I need?
