bkabina
Everything posted by bkabina
  1. This isnt my stuff.Posting for a friend. His E-bay items
  2. You have to run 795's in the 65mm bore version because the blaster pistons start at 66mm bore wich is standard bore.
  3. Thats about the best deal you will find other than Passion.The cylinders you are asking about are plated and come with the stock cub port set-up.With good reeds,carbs,pipes,and head,You could see as much as 95hp from the stock port set-up.
  4. SOLD*** Thanks DemonShee
  5. Yes it is still forsale.
  6. It is a 3 cylinder but not banshee triple.Its a snowmobile engine.
  7. The cubs are holding there own.
  8. I may be able to throw in some 40 over 795 series pistons if I can find them.Probably gonna need new rings though.I will see if I can find them and take some pictures.
  9. With a 68mm bore and 68mm stroke it would be 494cc.Yeah your gonna need more than a good trenching though.
  10. They are expected to be in the 140's.
  11. I thought the A-arms were sold
  12. Then why post anything at all?
  13. 4mill cubs on gas can hit 100+hp easy.Its everything else that will determine it.
  14. http://motors.search.ebay.com/_W0QQsassZbkabina
  15. I cut some usless tabs off too.
  16. Like new $400. shipped to your door.Will include cylinder stroker plate and/or head spacer plate if wanted.It is trued and fully welded.
  17. Shearer
  18. Cut turf tamers,or ohtsu radials.The H tracks.Maybe the Kendas to.Either 3 of these should work better than the others mentioned.
  19. Post me some pictures of the Lectrons.
  20. E-bay
  21. What all do you have left?And how much for all of it?
  22. The Boss Racing intake matches perfect to the VF3 Just get the smaller boots when you order.
