bkabina
Everything posted by bkabina
  1. If you don't mind me asking, What is with the setup that you are unhappy about? Just looking at the picture, it seems like it would steer better if the outter tie rod ends where moved closer to the spindles.
  2. I hope Jeff doesn't mind but I borrowed this picture from his website. the pipe on the left is big bore and the right is small bore.
  3. The easiest way would be to look at the pipe where it conects to the exhaust flange. If it is almost the same diameter they are big bore. If the the pipe is small enough and looks like it fits into a step down in the exhaust flange then they are small bore. Post a good picture of the exhaust flange.
  4. Rudy's shit runs hard period! He has been having some health problems and has moved closer to his daughter. Thats why he is harder to get ahold and stopped doing machine work. Thats all I am saying.
  5. Here are some better pictures of the 20mm DMX pipes. Here is a picture to compare them with a set of custom built 10mm pipes. They are not the same brand as the sniper's. They just help show the actual size of this set of snipers.
  6. Would also trade for a stock stroke cub preferably unported,that doesn't need too much work. I am always looking for drag parts.Straight cuts,J arms,Carbs...
  7. I have a set of cylinders that were drag ported by Jim at Passion Racing. They are for a 4mm crank and they are 65.50mm bore. They should be ready to run with a hone and new rings. I have a used set of longrod pistons that I will include, and two sets of domes cut for the cylinders. If I remember right, the domes are 19cc. I had these cylinders for along time and have been very pleased with them. I am running the cylinders now, but will take them off anytime. Don't know what to ask for them so I will start at $400. shipped for everything listed. Or make an offer. Or I may trade for just about anything. Preferable Banshee stuff. Let me know what you got. PM's are best.
  8. Wow!! I want to see what inframe DM pipes look like! Not being a dick, I just can't imagine an inframe after seeing the folger's can sized oof DM pipes available. Your legs wouldn't like it very much, I'm guessing? Actually I don't think it is possible to make an inframe. The only part of the pipe that would be is the silencer. lol
  9. Not looking to trade, but here are more pictures.
  10. Or make an offer
  11. I have a set of V-force 3 reeds for a t-rex topend. They were used very little. I can get better pictures if you want. $180. shipped
  12. Do you have a picture of the pipe and flange?
  13. Measure the pipe behind the flange, where it goes on the cylinder. The pipe on a big bore is bigger.Some big bore and small bore pipes use the same stinger. Let us know what they measure at the stingers and right behind the flanges.
  14. Got one.Thanks
  15. Still looking
  16. Nevermind. Don't need any.
  17. BUMP!! Anyone got some or know of any? Cash in hand! Ready to buy. Also need a cable for thumb and some intakes.
  18. Thanks but I need gas carbs.
  19. I need a set of Keihin 35 pwks, pm me with what you got.Thanks...
