banshee52 Posted May 29, 2008 Report Posted May 29, 2008 Guys, My thumb is about to fall off after riding the dunes for more than 45 minutes. Am thinking about changing to a twist throttle. How many of you have done this, and is it worth it or should I get a thumb throttle extender thingy? Quote
Da-shee-s-nit Posted May 29, 2008 Report Posted May 29, 2008 Guys, My thumb is about to fall off after riding the dunes for more than 45 minutes. Am thinking about changing to a twist throttle. How many of you have done this, and is it worth it or should I get a thumb throttle extender thingy? CHECK THIS OUT BRO! THE ANSWER TO ALL YOUR PROBLEMS :biggrin: HOPE THIS HELPS ...................................CLICKY :yelrotflmao: Quote
KaosBanshee44 Posted May 29, 2008 Report Posted May 29, 2008 Thumb Throttle = a long healthy life Twist Throttle = death My opinion Quote
Flash and Flare Posted May 29, 2008 Report Posted May 29, 2008 I thought a twist was what I wanted after buying my banshe.............BOY WAS I WRONG. It may work well for some, but I almost died a few times. Twist works great on bikes cause you can lean with the bike, quad don't lean like a bike and thats were it got me. I know run a 250r thumb throttle with cut springs, just carefull with cutting springs, the air velocity can keep the slides open when you let off if you cut to much off. F&F Quote
BellicoseBanshee Posted May 30, 2008 Report Posted May 30, 2008 I don't know why, but I can ride a dirt bike with twist all day, no problem. On ATVs, I just do not like it. So, I suppose it depends which you prefer. Many people use a twist with no issues... Quote
Animalman294 Posted May 30, 2008 Report Posted May 30, 2008 Ya, thumb throttles are the way to go. Why do you think most quads have thumb throttles and not dirtbike twist throttle's............? Quote
BaNsHeEs RuLe! Posted May 30, 2008 Report Posted May 30, 2008 Well, I guess I am the only one, but I bought the Terrycable dual gasser so I could twist when cruising and thumb when shredding. After the first ride I noticed I never went to the thumb trottle. I stayed on the twist. After about 6 or 7 rides, I never used the thumb. I ride tight trails, GNCC type stuff and some dunes and the twist is great, no thumb pump, you can lean way back and nail it and let the front just float over bumps and shit. Great for dragging too. I took the terrycable off as it was a bit bulky and put a Motion Pro CR style twist on and will never go back to the thumb. You get better grip as your whole hand is on the bar and no thumb pump. I feel a lot more stable with the twist. I did put a steering dampner on to prevent any deadly bumpsteer. The only place I have had any scares is hill climbing, it's hard to pull your self up to the front of the quad going up a steep hill and not goose it. But , hey....I don't hillclimb much. I would go with the TerryCable and check it out first and see if you like it. I would never go back to thumbing it. Quote
peak-j Posted May 30, 2008 Report Posted May 30, 2008 Terry Cable Dual Gasser, I use my twist for cruising across the open sand or open fields, then switch to thumb when jumping or climbing dunes. Works great for me. Quote
monster_energy06 Posted May 30, 2008 Report Posted May 30, 2008 i had a twist thorttle on my shee befor and never again. i whiped out pretty bad on a wheelie.. ive never had a sore thumb using the fliper..ever, even on my sno- sled pulling dual 38's flat slides... i guess its indurance from all the sno-x,u just get used to it imo. ive had alot of ppl ride my shee and sled telling me they have a sore thumb.... in yur case get an after market thumb throtle even a honda thorttle. Quote
banshee52 Posted May 30, 2008 Author Report Posted May 30, 2008 Thanks for all the great info! I may go with the Terry cable dual gasser. Will check the other options also. Quote
2001Stroker Posted May 30, 2008 Report Posted May 30, 2008 I posted the same question a few months ago. I got alot of replies to it, but I erased the thread. Most everyone said to stay with the thumb throttle. I'm glad I did. I ordered a Moose Racing polished thumb throttle. It's pretty much universal, and has a few different cable adjustments. I have 2, 35mm Keihin's, and it pulls them great. I was actually able to get my slides to open all the way with this one, over the stock thumb throttle. It looks very good, and has cut back on alot of my thumb fatigue. I think I either got it from RMATV or MotoSport. This is the one that I bought. http://www.mooseracing.com/catalog.jsp?lev...amp;startPage=1 Quote
Frogger Posted May 30, 2008 Report Posted May 30, 2008 (edited) My thumb gets tired the first time or two out riding. Then after that I'm fine. Just work that thumb out and you'll be fine. Edited May 30, 2008 by Frogger Quote
banshee52 Posted May 30, 2008 Author Report Posted May 30, 2008 Thanks 2001stroker, I checked the link, and I like what I see. Will probably go with that setup or maybe the terrycable dual gasser. Quote
NitroTate Posted May 30, 2008 Report Posted May 30, 2008 I have the terry cable also. I had a twist for the past 8 years and hadn't even ever used a thumb. I liked the twist a lot and once you get used to knowing that you need to be careful you tend to be alright. Never had any bad scares. Now I have both and I do like the thumb more for rippin around and up hills etc. but I LOVE the twist for longer rides or on trails. Quote
BaNsHeEs RuLe! Posted May 31, 2008 Report Posted May 31, 2008 I have the terry cable also. I had a twist for the past 8 years and hadn't even ever used a thumb. I liked the twist a lot and once you get used to knowing that you need to be careful you tend to be alright. Never had any bad scares. Now I have both and I do like the thumb more for rippin around and up hills etc. but I LOVE the twist for longer rides or on trails. Yea, the twist is definatly worth it once you learn it. Quote
