kirk3000 Posted May 19, 2008 Report Share Posted May 19, 2008 my banshee ran great last night. this morning it started no problem after i washed it. then it idled and died, it wont start now. this happened to me before (exact same problem) and i dont know what to do. last time i had to take it to the shop and it cost me $1000. has anyone else had this problem? if so i could use your wise words of advice. Quote Link to comment Share on other sites More sharing options...
No Limit Powersports Posted May 19, 2008 Report Share Posted May 19, 2008 Well first things first you need to check to see if you got spark? Then we can go from there Quote Link to comment Share on other sites More sharing options...
LS1Inferno Posted May 19, 2008 Report Share Posted May 19, 2008 $1000 dig out the receipts sounds like they screwed you. Yep basic tests, spark fuel. timing, reeds, start with the simple and work your way from there. Quote Link to comment Share on other sites More sharing options...
monster_energy06 Posted May 19, 2008 Report Share Posted May 19, 2008 man for a 1000$ what was werong with it ??? the first time Quote Link to comment Share on other sites More sharing options...
LS1Inferno Posted May 20, 2008 Report Share Posted May 20, 2008 man for a 1000$ what was werong with it ??? the first time Yeah no shit. i can go through a banshee with newish everything for less then that. Quote Link to comment Share on other sites More sharing options...
Screaming Yellow Zonker Posted May 20, 2008 Report Share Posted May 20, 2008 I would start off with unplugging all connectors and dry them out. I would also spray some wd40 in the connectors. Than I would a spark test.. Quote Link to comment Share on other sites More sharing options...
Animalman294 Posted May 21, 2008 Report Share Posted May 21, 2008 Ya, if it does this after you wash it then something is grounding out................. $1000.00 man I'm in the wrong business.................. Quote Link to comment Share on other sites More sharing options...
klemet banshee Posted May 21, 2008 Report Share Posted May 21, 2008 check your coil adn ur electrical mine does the same thing i think its escared :yelrotflmao: Quote Link to comment Share on other sites More sharing options...
kirk3000 Posted May 22, 2008 Author Report Share Posted May 22, 2008 i have a good spark, but my plugs were covered in gas. i cleaned them but still nothing. and the $1000 was alot of little things, not just the big problem. shoulda said that Quote Link to comment Share on other sites More sharing options...
bunboy1 Posted May 22, 2008 Report Share Posted May 22, 2008 every time i wash my bike i need to pull the choke out to start it afterwards. if you got pods, did you spray water into them? Quote Link to comment Share on other sites More sharing options...
