lownslow1988 Posted January 31, 2008 Report Posted January 31, 2008 hey guys i just picked up a 05 Banshee and found this site....the quad is a limited edition 05...black with flames.. it is totally bone stock at the moment...i bought it cheap since it was needing a new top end...i had it bored .20 over and got a Wiseco forged piston and top end kit...parts will be here tomorow so i can put it back together....i also ordered a set of Vforce 3 reed valves...a friend of mine said they make a big improvement over stock so i got them....im just wondering what my next mods should be...my buddy has a 05 trx450r quad so id like to hang with him or beat him eventually....i havent ridden a banshee yet so i dunno its power...ive read a few topics on the site and it seems everyone says +4 timing, pipes, filter and jet kit.....i was looking at Toomey T5s or the Pro Circuit pipes...where is the best place to order banshee parts at the best price......i also want to get a TORS eliminator kit as the PO was messing with them and ive read they are problematic....thanks for the help Quote
zach45 Posted January 31, 2008 Report Posted January 31, 2008 get toomeys and a k&n take the air box lid of and timing plate at +4.. should blow ur friend away.. Quote
shee4speed Posted January 31, 2008 Report Posted January 31, 2008 Sounds like your on the right track on them mods. Soon get a port job and spank everyone of your buddies 450's. Welcome to the boards. Quote
runger Posted January 31, 2008 Report Posted January 31, 2008 hey guys i just picked up a 05 Banshee and found this site....the quad is a limited edition 05...black with flames.. it is totally bone stock at the moment...i bought it cheap since it was needing a new top end...i had it bored .20 over and got a Wiseco forged piston and top end kit...parts will be here tomorow so i can put it back together....i also ordered a set of Vforce 3 reed valves...a friend of mine said they make a big improvement over stock so i got them....im just wondering what my next mods should be...my buddy has a 05 trx450r quad so id like to hang with him or beat him eventually....i havent ridden a banshee yet so i dunno its power...ive read a few topics on the site and it seems everyone says +4 timing, pipes, filter and jet kit.....i was looking at Toomey T5s or the Pro Circuit pipes...where is the best place to order banshee parts at the best price......i also want to get a TORS eliminator kit as the PO was messing with them and ive read they are problematic....thanks for the help Well u should go with cool head and domes which verys on type of fuel you want to run,k&n air filters,new cdi which will put you at 4 degress on your timing ,and then go for a bigger swingarm,+ 2 a arms, I had found alot on ebay with buy it now Quote
lownslow1988 Posted January 31, 2008 Author Report Posted January 31, 2008 Well u should go with cool head and domes which verys on type of fuel you want to run,k&n air filters,new cdi which will put you at 4 degress on your timing ,and then go for a bigger swingarm,+ 2 a arms, I had found alot on ebay with buy it now a guy i know says he has a coolhead for sale..im waiting to hear from him on a price for it...what size domes should i go with...i plan to run 93 octane fuel....is the cdi box better then the timing plate to pull timing?? Quote
wacko2000 Posted January 31, 2008 Report Posted January 31, 2008 I dont kno your elevation but I have 20-21 cc domes, dont remember which and I have 155psi in each cylinder... If you have never ridden a banshee before, you should start working out you biceps- triceps- shoulders. etc.... they quite often try to rip your arms off....lol I would start with some pipes- toomey or pro circuit both good pipes.. A good air filter and timing plate..It will really wake her up big time...I dont think you wll have a prob with the 450 unless he has some series mods... If that aint fast enough bump the compression and get that bitch ported.. o0o yea welcome to the HQ Quote
lownslow1988 Posted January 31, 2008 Author Report Posted January 31, 2008 I dont kno your elevation but I have 20-21 cc domes, dont remember which and I have 155psi in each cylinder...If you have never ridden a banshee before, you should start working out you biceps- triceps- shoulders. etc.... they quite often try to rip your arms off....lol I would start with some pipes- toomey or pro circuit both good pipes.. A good air filter and timing plate..It will really wake her up big time...I dont think you wll have a prob with the 450 unless he has some series mods... If that aint fast enough bump the compression and get that bitch ported.. o0o yea welcome to the HQ im in 08859 NJ...elevation is 80...where are all you guys buying your parts from?? Quote
xsinnerx Posted January 31, 2008 Report Posted January 31, 2008 if you want to run pump gas then go with 20 or 21 cc domes, get your bolt on mods first, which are the cool head, you have your reeds already, get a $35 ricky stator plate and advace your timing at +4, pipes, I dont think you can go wrong with t-5's unless you are looking for more of a bottom end pipe. You can find some good deals on here, ebay, planetsand, and everything2stroke, for almost all your mods, I would seriously look into buying used instead of retail unless you have lots of cash to spend. After you have all your bolt ons I would spend some cash on suspention, porting and so on. you should be fine with stock carbs with your bolt ons but once you port you will probably want bigger carb which need bigger manifolds, bigger filters, and with that extra power your maybe gonna want a longer swing arm, so that means new chain, different sprokets, lol you are gonna go broke, welcome to the HQ!!! Quote
jcbanshee Posted January 31, 2008 Report Posted January 31, 2008 go with the toomeys and then advance your timing to 4+ Quote
cvbadass Posted January 31, 2008 Report Posted January 31, 2008 You should beat most 450s with just some pipes, I also here that the vitos super stock pistons with a vitos hemi head would be a significant increase for about $500. I am ordering mine from vitos performance, I am in florida. also rockymountainatv.com, motosport.com. Quote
530grafix Posted January 31, 2008 Report Posted January 31, 2008 Ditch the airbox and go with pods and outerwears.. :thumbsup: Quote
bansheeman1988 Posted January 31, 2008 Report Posted January 31, 2008 First off welcome to your new home on the web, second, as everyone has made a good point above do the PC or T5 pipes, stator plate (cheaper than a whole new 250$$ CDI), K&N and remove that lid, Coolhead with about 20cc domes and you should see some damn noticable power!! Quote
98'banshee Posted January 31, 2008 Report Posted January 31, 2008 (edited) The absolute 1st mod anyone should tell you to do is pipes. I recomend toomeys, T-6's if you dont port it and T-5's if you do or arn't sure if you will in the future. With 155lbs of compression you may want to look into some Engine Ice instead of Antifreeze and maybe replace the stock impeller with an aluminum one. I personally HATE my Pod filter because you may run into some wet spots on the trail and would much rather have the airbox with the top removed. Welcome to BHQ and eventually to the banshee owner club where you never will have enough money to fill the bottomless pit of mods. :biggrin: You should be close to your buddy stock and it will take just pipes to kill him, if you start pulling some good power I also recomend going up a tooth on your front sprocket, and remember to lean forward when you launch hard cuz as soon as you hook in the power band you will be sorry if you dont. Edited January 31, 2008 by 98'banshee Quote
lownslow1988 Posted February 1, 2008 Author Report Posted February 1, 2008 well the top end kit came in today and i just finished assembly on it...took it for my first ride....the thing is pretty fast although i didnt get onto it much...i cruised around for a lil bit to break it in...im gonna order the pipes in the next week or so...gotta sell my 400ex first...it runs good but needs some carb tuning....previous owner screwed with the TORS screw and carb screws....anyone know a good starting point to get it running from....it doesnt want to idle and backfires now and then....i made sure the carb bowls are on right carbs and the tors are in the right carbs... where do i get the timing plate from??....ive found pretty good deals on the T5's on ebay new for around 550.. unless you guys know a cheaper place....thanks again Quote
