lownslow1988
Everything posted by lownslow1988
2005 Special Edition Banshee for sale 2500 NJ
lownslow1988 replied to lownslow1988's topic in For Sale - Parts & Accessories
PM sent -
well i did some looking into why it doesnt run right and found the problem....its only running on 1 cylinder...the right side has no compression....so i assume the rings are shot somehow...they are only less then a year old...so ill take 2000 on it.... someone come take it away -
give me a email and i can send pics.... -
any takers...make me an offer on it -
selling my 05 shee....it is black special edition with the flamed graphics....it is pretty much all original except i did a .020 wiseco top end kit beginning of this year and a set of VForce 3 reeds and Rental bars...i got it from my friend who is the original owner....located in 08859 NJ....it has been sitting for a few months and runs shitty but does run.....i think the carbs could use a cleaning but im not sure as i dont know much about these quads....known problems are that the upper right a arm is bent, and front right plastic fender is cracked....i did the zip tie trick and it is holding up and in position.....not too bad....i rolled it on the side and it bent the arm n cracked plastic....will not ship so local pickup only....no current pics but i have a camera phone pic of it... anyone local and serious can come and check it out...i have tried to truely and accurately describe this....2500 or best offer edit....couldnt figure how to post pics...i can email it though and maybe someone can post for me
01 Banshee a-arms, tie rods, spindals
lownslow1988 replied to hawke's topic in For Sale - Parts & Accessories
would u sell just the upper right arm? if so PM me with a price on it..thanks -
looking to buy a right side upper A arm for my 05 banshee....balljoint and bushings must be in good shape....give me a price shipped to 08859 NJ if anyone has one....thanks
it was grounded right by the back where the grab bar mounts and thats right where i welded....the guy with the loaner electronics never came thru so im stuck again
i checked all the wires and theres nothing wrong with the harness itself
well i found a guy that is gonna let me swap his coil and cdi.......just waiting on him to come thru....ill let you all know what it turns up being.....in the mean time im open for more ideas on testing
it still only runs on 1 cylinder....when i check for spark it doesnt show any....but if i keep kicking it 20-30times really quick it will fire up but only 1 side....ive done compression check and it has 100psi...ive tested the coil as it shows in the FAQ and the primary resistance is good but when i go to the secondary it doesnt read..ive takent the capa off and no change...the resistance on the caps themselves are different then each other....the FAQ says that it means its shot, but i went to the yamaha dealer and the head tech said it was good when he tested it.....suprisingly they didnt try to sell me one since it was in stock....i need to get this running on the cheap....i think the coil is shot but dont wanna waste 75 on it and it not be the case.....id imagine the head tech thats been at the shop knows what he's doing or should i not??? anyone local to central NJ that would be willing to swap parts with me to figure it out??
can they test the cdi?? everyone says they cant be tested...idont wanna waste money buying wrong parts
well i went out with the diagrams from the above link, and it started up first kick like it always does....they would rule out the cdi box correct???? but it was only running on 1 cylinder....i did drop that plug though when i pulled them....ive got new plugs to go in but havent gotten back there since.....whats my chances that its gonna run good with just new plugs....i thought about it and i welded the other side exhaust bracket without unhooking any electronics and its been fine since
i sent you a PM
it was grounded at the back and welded at the back....the voltage regulator and the ground were unmounted from the frame...
i didnt think to unhook any electronics.....i dont have access to any other shee's....is there anyway to test the electronics so i dont have to buy parts i dont need
05 banshee....i had to do some welding on the exhaust bracket to frame on the quad this morning....now it wont start....it started up this morning with 1 kick....now its getting no spark it seems...what did i burn up???
im looking to buy a right upper Aarm for my 05 banshee.....also a rear grab bar.....stock or aftermarket...i have nothing right now.....give me prices shipped to 08859 NJ and send pics to [email protected] if you have them
Some parts for sale, T5s, DG nerf bars, etc..
lownslow1988 replied to PSYKO's topic in For Sale - Parts & Accessories
ill take the toomeys for 250 if you will take a COD that way we are both garented to get our stuff and the handel bars too..... maybe the carbs too!!!!! are the carbs jetted for using the tors elimator cables?? give me a price on them too.....alll shipped to 08859 NJ -
ill take the toomeys for 250 if you will take a COD that way we are both garented to get our stuff and the handel bars too -
Stock 05 Banshee...First mods?
lownslow1988 replied to lownslow1988's topic in Banshee Repairs and Mods
well the top end kit came in today and i just finished assembly on it...took it for my first ride....the thing is pretty fast although i didnt get onto it much...i cruised around for a lil bit to break it in...im gonna order the pipes in the next week or so...gotta sell my 400ex first...it runs good but needs some carb tuning....previous owner screwed with the TORS screw and carb screws....anyone know a good starting point to get it running from....it doesnt want to idle and backfires now and then....i made sure the carb bowls are on right carbs and the tors are in the right carbs... where do i get the timing plate from??....ive found pretty good deals on the T5's on ebay new for around 550.. unless you guys know a cheaper place....thanks again -
im in 08859 NJ...elevation is 80...where are all you guys buying your parts from?? -
a guy i know says he has a coolhead for sale..im waiting to hear from him on a price for it...what size domes should i go with...i plan to run 93 octane fuel....is the cdi box better then the timing plate to pull timing?? -
hey guys i just picked up a 05 Banshee and found this site....the quad is a limited edition 05...black with flames.. it is totally bone stock at the moment...i bought it cheap since it was needing a new top end...i had it bored .20 over and got a Wiseco forged piston and top end kit...parts will be here tomorow so i can put it back together....i also ordered a set of Vforce 3 reed valves...a friend of mine said they make a big improvement over stock so i got them....im just wondering what my next mods should be...my buddy has a 05 trx450r quad so id like to hang with him or beat him eventually....i havent ridden a banshee yet so i dunno its power...ive read a few topics on the site and it seems everyone says +4 timing, pipes, filter and jet kit.....i was looking at Toomey T5s or the Pro Circuit pipes...where is the best place to order banshee parts at the best price......i also want to get a TORS eliminator kit as the PO was messing with them and ive read they are problematic....thanks for the help
