fitz18 Posted November 3, 2007 Report Posted November 3, 2007 Just thought I'd post up my latest problem with my rebuild. Obviously the last owner deciced to weld this nut on the shaft!! Ive no idea why. Any suggestions? You's think it can be fixed? Quote
04titanse Posted November 3, 2007 Report Posted November 3, 2007 damn man thats terrible. I cant imagine there is a good way to salvage that shaft. i guess the only way to find out would be to cut off the very very end and see if you can get that bolt off and manage to thread a new one on. but my guess is that you wont be able to reuse that and you will be replacing the entiire shaft back into the tranny. best of luck! Quote
wacko2000 Posted November 3, 2007 Report Posted November 3, 2007 Wow what a asshole. that is terrible, I also cant see being able to salvege that, looks like he put a good amount of weld on that, good luck man, keep us updated... Quote
bonzai272 Posted November 3, 2007 Report Posted November 3, 2007 What about slowly and carefully grinding it down with a grinder? then try backing the nut off? Quote
locogato11283 Posted November 3, 2007 Report Posted November 3, 2007 what the fuck?! i seriously doubt thats gonna be usable after the nut comes off. youd have to take a grinder or a torch to it. prolly be better of buying a new shaft for it. Quote
4stroker Posted November 3, 2007 Report Posted November 3, 2007 is that an axle nut he used??? a friend just bought a banshee with this exact "mod" lol. he went and bought a whole new shaft from yamaha for only $120. (aus) the same banshee also had the splines on the axle and sprocket hub stripped, and it had a dirty big grub screw through them both to "fix" it he knew all this when buying it though, it was a cheap banshee! Quote
fitz18 Posted November 3, 2007 Author Report Posted November 3, 2007 I know it sucks! Think il take the torch to it and then try to back the nut off. May as well give it a go before I buy a new one! Thanks for the feed back guys. I guess you just never know what you'll find with a used bike! Quote
wacko2000 Posted November 3, 2007 Report Posted November 3, 2007 I guess It can't hurt to give a shot, good luck, maybe you'll get lucky.. Quote
JdiZzla Posted November 3, 2007 Report Posted November 3, 2007 I know it sucks! Think il take the torch to it and then try to back the nut off. May as well give it a go before I buy a new one! Thanks for the feed back guys. I guess you just never know what you'll find with a used bike! I would use a grinder first and try to wear it down as thin as you can. That is a lot of weld to get hot enough to break it off, grind it down, torch it, then just hammer away with an impact wrench Quote
jbooker82 Posted November 3, 2007 Report Posted November 3, 2007 Chances are if it is welded on there the threads on the shaft are alread screwed. I would try to get the sprocket off and then buy a used tranny and put it in. Then you would have some extra spare parts. Quote
theshee Posted November 3, 2007 Report Posted November 3, 2007 Its screwed. I wouldnt even waste any time messing with it. thats not even the right nut for that shaft. Most likley some nar nar put the wrong nut on there, stripped it out and then welded it on. Pretty retarted. Get a used tranny and fix it right. :thumbsup: Quote
BigRed350x Posted November 3, 2007 Report Posted November 3, 2007 Check cascade innovations I think it is... you can get that shaft for under $100. If you are careful you can re-use the c-clips and stuff yourself. Don't send it to a builder, you can do it yourself with a $30 flymer manual if you have any kinda know-how with mechanical stuff. - Jared Quote
