whats up everyone. i have a 2003 chevy silverado. 50,000 miles on it. drives great except for between the speends of 55 and 65 mph. it shakes. anything below 55 and its fine, anyt thing over 65 and its fine, anything between 55 and 65 and it shakes?
anyone exp. this w their truck? any one have any idea what it might be?
thanks
  • Replies 31
  • Created
  • Last Reply
Top Posters In This Topic
I had that happen years ago on a car of mine, and it was because of a broken belt in one of the tires. We didn't find it, until I had a flat, and went to get it fixed. I ended up buying a new tire.
one or more of your tires are out of balance, simple fix. get them balanced, mine is the same exact way. i just drive faster.
if it was the belt or tie rods wouldnt the shaking continue evan after 65 mph?
When the belt in the tire broke, it only had the "shakes", between 45, and 60 MPH. It was fine at lower speeds, and fine at higher speeds, but it hated certain speeds.
I would say get them re-balanced also. I had a set of 22's on my truck and I was doing the same thing, they rebalanced them and I was all good... I think I was missing a weight on one of the rims..
Spend the extra money and have a road force balance done on them.That way they can actually check for laderal,radial run out,bent wheels,seperated cords and get the actuall road force pounds of the tire and match mount the tires to get the road force pounds down to minimum amounts.You will notice the difference as soon as you get up to freeway speeds.
i checked the back and there clean. when i really lay on the gas from 40 to 80 you dont feel the vibration, but when i slowely go from 40 to 80 you will feel the shake at 55 to 65 then when i slow down same thing shakes at 55 to 65?
weird.
ill get the wheels checked tomorrow.
wee can i get the road force balance?
thanks
And if it's not your tires, could be your drive-shaft as well.
