YAMAGOOSE Posted September 4, 2007 Report Share Posted September 4, 2007 Took my shee out last week Quote Link to comment Share on other sites More sharing options...
RZBansheeMan Posted September 4, 2007 Report Share Posted September 4, 2007 Do you still have all the TORS shit on it ? Quote Link to comment Share on other sites More sharing options...
06BaNsHeE Posted September 4, 2007 Report Share Posted September 4, 2007 Sounds like a parking brake problem to me. Quote Link to comment Share on other sites More sharing options...
fox_forma Posted September 5, 2007 Report Share Posted September 5, 2007 Does it REV up but not go anywhere? If so you fried your clutch most likely. How big was the hill you came back down and did you pull the clutch is when coming down? Quote Link to comment Share on other sites More sharing options...
YAMAGOOSE Posted September 5, 2007 Author Report Share Posted September 5, 2007 (edited) Well when I rev it, it starts to go but only goes like 5mph? I put it in second, third, gears and it does the same?...how can I tell if its the clutch? If I open the clutch cover could you tell if its out? the clutch is like 6 months old on like 5 trips If it's the break, wouldn't it just burn out the tires? My back break is a little low tho? like way lower and loose below the peg? I do not have tors...replaced it with the eliminator kit Edited September 5, 2007 by YAMAGOOSE Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted September 5, 2007 Report Share Posted September 5, 2007 does it rev like normal or it doesn't rev, if it doesn't rev is it breaking up (or acting up at all) or does it rev normaly & just won't move fast? Quote Link to comment Share on other sites More sharing options...
YAMAGOOSE Posted September 5, 2007 Author Report Share Posted September 5, 2007 does it rev like normal or it doesn't rev, if it doesn't rev is it breaking up (or acting up at all) or does it rev normaly & just won't move fast? It revs but then you can feel lose the power quick by that time I have the gas opened all the way, and the bike sounds like it needs to go to the next gear..but then I shift and it does the same...almost like when you shift to 4th gear when going slow... Quote Link to comment Share on other sites More sharing options...
sa3ood_banshee Posted September 5, 2007 Report Share Posted September 5, 2007 (edited) you must have fouled a plug or 2 , it happened 2 me once ,just go and and buy new plugz(spark plugs) sa3ood Edited September 5, 2007 by sa3ood_banshee Quote Link to comment Share on other sites More sharing options...
blowit Posted September 5, 2007 Report Share Posted September 5, 2007 It revs but then you can feel lose the power quick by that time I have the gas opened all the way, and the bike sounds like it needs to go to the next gear..but then I shift and it does the same...almost like when you shift to 4th gear when going slow... Sounds like you are running on one. Change the plugs and go ride. Brandon Quote Link to comment Share on other sites More sharing options...
06BaNsHeE Posted September 5, 2007 Report Share Posted September 5, 2007 When My bike would run on one cylinder it would go more than 20 atleast. Quote Link to comment Share on other sites More sharing options...
doorslammer Posted September 6, 2007 Report Share Posted September 6, 2007 hey i had the same problem with all the same syptoms, my cause was electrical, some very fauly joints in the wiring harness hope this helps Quote Link to comment Share on other sites More sharing options...
