Hello,
please help me. I just bought an speedometer for my banshee. To install the speedometer, I need to demount the highlighted part on the picture, It's a part of front wheel or brake..
Pic:
Please FAST!
Thank you very much !!!
your brake caloper is holding the rotor from coming off, which is attached to the hub... looks like you have the nut to the hub off, remove the caliper & it should just pull off
Thank you for fast response!
But I don't exactly understand you, my english is not perfect.
Can you please paint it into the image what to do or something? 1000x tthanx!!
Thanx, but that is not te problem. I unmounted bolts from the caliper and still impossible to unmount the highlighted part :( Ther must be something else which protect the highlighted part from unmounting :((
If you removed the caliper bolts, you should be able to wiggle the caliper off from the rotor, and then I would "lightly" tap the hub with a small hammer and pull on it by hand.
It should come off from there.
It's impossible to wiggle it off because of the metal slim protector, do you underestand me? :)
Well, if you took the 2 caliper bolts out, then you should be able to get the whole hub assembly to come out just a little bit ( enough to clear the rock shield )then get your caliper off. Now the hub should come off.
Hey, Like What Everyone Has been Telling You, Take Off The 2 Bolts Holding On The Brake Caliper( The Think That Hold The Brake Pads in) And The Caliper Will Slide Out From The Rotor, And Than The Hub That You Have Highlited Will Slide Off The Spindle
Give it a good whack with the rubber mallet. Not just a few taps, whack it good...with a rubber mallet you shouldn't damage it either.
If you have removed the brake caliper from the rotor, and you've removed the nut that holds the hub (part highlighted), then there is nothing else to keep that hub from coming off.
If you need some more leverage, mount the wheel back on the hub and use the wheel to help pull the hub off. :thumbsup:
Thanks all for ansvers.
But Iam still unsuccesfull.
Next pic:
so i removed that 2 bolts(blue highlight)
but I still cannot remove the brake caliper (black highlight)
because of that red highlighted thing, which is impossible to demount, because 2 bbolts of it are between the brake disc and that red highlighted thing.
Please help me :'(
