pepehaha
Recent Profile Visitors
1,259 profile views
pepehaha's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. Hi all, I've been using a 10W40 tranny oil instead of the reccomended one, is that a problem? Should I rather buy the reccomended one? Thanks
  2. Oh Iam sorry man, I was tired and thought that you had +4 swinger, which would be indeed retarded for mx, +4 axle and +2/+3 a arms are fine for mx of course.
  3. +4 axle for mx is absolutely retarded
  4. Yeah I've read that too about the magnet coming loose, I won't use it. But while tapping a bigger thread, Iam afraid of few pieces of metal getting into the tranny..
  5. So I was changing tranny oil in my shee, and I replaced the stock screw(on the bottom of the cases, when changing oil I remove it and the oil flows through the hole, I put it back in and fill with new oil), I replaced it with some super duper screw from ebay with magnetic end. The fuckers said it was for banshee, but I screwed it in and realized that it has a little bit different thread, so I removed it and now the thread in the hole in the cases is fucked, and the stock screw is impossible to tighten - I hope you know what I mean. How to fix this? Helicoil? If so, which size or type? Thanks
  6. I have removed tors, I haven't lubed the cable (it's in "protective hose", it is impossible to lube, isn't it?) It get's never stuck, unless It get's in contact with water..
  7. Yes, I have stock carbs. I have lid on, with holes drilled in it. Whenever I wash my shee, I ducktape the holes in airbox lid, so absolutely NO WATER AT ALL gets onto the air filter (I use KN w/ outerwear). So you are saying I should invest in new carbs for safety reasons? Which ones do you reccomend, and which size? Stock? I don't want to increase mileage. Right now I have these motor mods: Timing plate +4, kn airfilter w/ holes in lid, toomey T5's,
  8. Whenever I either clean my shee with high-pressure water cleaner, or ride through deep water and then ride, first 10 minutes the throttle gets randomly stuck. When I wash my shee and wait 24 hours before riding, it does the same thing. What causes this? Where gets the water and it's not supposed to? Are the slides in carbs causing this? And my second question, when I have opened the fuel valve, and accelerate, it bogs and backfires and dies - I suppose it's not getting enough fuel through. When I switch to reserve, everything works fine - should I remove the fuel valve and clean it? I can't imagine how it could get dirty... Thanks!
  9. what a feedback, some people are idiots :-/
  10. The 1500$ price includes lt quadrate shocks AND janssen lt a arms. I have that setup, got it for 1200 from ebay, and I absolutely love it!
  11. How old is the LSR swingarm? Does it have rear skid plate mounts? Might be interested
  12. well yes, but I didn't buy them directly from jassens, but from ebay as a kit with elka shocks... And the bent was caused because of crash, no error in material, I'am afraid that the won't send me new ones for free... But I can try and send them an email... If you have some experience with bent arms and warranty, let me know if you got new ones...
  13. Hi, I just bent my jannssen racing LT a arms :-( and Iam lookingfor new ones. Which ones do you reccomend? I wasnt extremely satisfied with the janssen ones, shitty ball joints etc... I had +2 ones, would you reccomend me buying +3 ones? I ride mostly fast trails and woods... And which brand? I prolly wont buy janssens again... I was thinkink about laegar's, what do you think? They cost about 760$ on sale now... And I can choose whether I wan +2, +2+1 or +3 ones... Roll design looks super sweet but unacceptable price (1350$=-O) Thanks
  14. Hi, I need to know Part number of the yamaha kickstart rebuild kit.. My kickstarter makes a rattling noise while riding... Thanks
  15. Hi, I recently purchased this intake adaptor for my kn filter, because the stock made from cut sceleton of the stock filter is starting to break: But I have problems while installing it, should I drill two holes to the airbox and put there the screws through the airbox and adaptor? And It doesn'tfit perfectly, so I'am afraid of air leaks, because It's just one piece of plastics, no foam seal like the stock one... How to install it properly? Thank you
