somewhere in time Posted August 15, 2007 Report Posted August 15, 2007 I just bought a modded 2003 Banshee and have no idea what ratio or oil I should be using. The guy I bought it from did not know. I thought that was strange too! Here is the run down. Full Toomey exhaust Cool Head Wiseco Pistons K&N cone filters jetted Appears to have aftermarket carbs on it. It runs and idles perfect now. I wish I new what oil/fuel and ratio was in the tank now. Any suggestions would be greatly appreciated. Don't know if this helps but I am at 600 ft above sea level in TX Thanks!! Alex Quote
peak-j Posted August 15, 2007 Report Posted August 15, 2007 First thing you should do is a compression test since it has a coolhead on it. If you don't know what your compression is you will have a hard time finding out if you need to run higher octane fuel. As far as mix I have ran yamalube 2r or whatever it was, and I recently switched to Klotz supertechniplate. I didn't notice any change except for it doesn't smell like shit. Yamalube smells bad. I'm not saying you should run a certain mix off of smell either!!!! Also you would think he would know what fuel he was running in it, kinda weird. Hope this helps. Quote
MSBansheeDrags Posted August 15, 2007 Report Posted August 15, 2007 I just bought a modded 2003 Banshee and have no idea what ratio or oil I should be using. The guy I bought it from did not know. I thought that was strange too! Here is the run down. Full Toomey exhaust Cool Head Wiseco Pistons K&N cone filters jetted Appears to have aftermarket carbs on it. It runs and idles perfect now. I wish I new what oil/fuel and ratio was in the tank now. Any suggestions would be greatly appreciated. Don't know if this helps but I am at 600 ft above sea level in TX Thanks!! Alex i like the klotz supertechniplate at 32:1 for premix with 110 octane racing fuel and honda hp 80/85 in the tranny....dbr Quote
350BANSHEE350 Posted August 15, 2007 Report Posted August 15, 2007 i use amsoil interceptor or dominator (switching to dominator) at 36:1 and i like it for the tranny i find that shell rotella 15w40 heavy duty diesel oil works awesome and its cheap do a compression test and a plug chop 2 most important things Quote
chevrolet banshee Posted August 15, 2007 Report Posted August 15, 2007 i run maxima castrol 927 32-1 it smells good to :thumbsup: Quote
fox_forma Posted August 15, 2007 Report Posted August 15, 2007 40:1 with all my 2t's with a good quality pre-mix oil. Never had any problems. I tend to lean towards Mobile Racing 2t oil, can be had at autozone for a fair price and seems to burn quite clean Quote
_Hex* Posted August 15, 2007 Report Posted August 15, 2007 i run 32:1 castor 927 with vp ahhh smell like victory to me LOL. as far as elevation and jetting u wont notice until ur on the top end, if it bogs out and doesnt feel like all the power is getting out ur prob running to rich Quote
_Hex* Posted August 15, 2007 Report Posted August 15, 2007 dude i just cleaned out some carbs that had techniplate sitting in them for a bit it was very foul smelling! Quote
somewhere in time Posted August 15, 2007 Author Report Posted August 15, 2007 Thanks for the help guys. I will run a compression test soon and post it for more advice. Also.... What does "plug chop" mean. Thanks! Quote
BellicoseBanshee Posted August 18, 2007 Report Posted August 18, 2007 Thanks for the help guys. I will run a compression test soon and post it for more advice. Also.... What does "plug chop" mean. Thanks! Found this in the forums some time ago: Plug Chop Quote
