Everything posted by chevrolet banshee
building a trail/sand motor.... need help
chevrolet banshee replied to thrill-billy85's topic in Banshee Repairs and Mods
What youll probily want is a set of 32mm pwk's with a boss intake and some v force reeds a dune/play port from fast with your cool head and some t5 pipes and youll be set. as far as the bad startind/running always start with the plugs (seams like its always the simple things) your probily to rich to. when its parked not running do you smell fuel? thats with the petcock on. if so that night be you have float issues, but proper jetting will make a diffrance in starting. hope i helped Chevshee -
1996 Banshee
chevrolet banshee replied to chevrolet banshee's topic in For Sale - Parts & Accessories
no one -
1996 Banshee
A 250 or bigger, i would like a crf250r or a cr250, a kx would be cool to. pretty much anything. what you got? Chevshee -
1996 Banshee
I guess they got rid of the edit button so if your interested give me a call when ever. 1-208-301-0501 Chevshee -
I dont really want to but i think im going to sell my banshee. its a 1996 banshee, resent rebuild .30 over, it has 35mm pwk's knock off k&n pods boss intakie, boisen reeds, fmf fattys and only year old sliencers. its got pro taper bars and a twist throttle. cut front and rear fenders. stanless steel +2 axle its got the chevy elmblem cut into stanless for the grill. it runs pretty good i just put a transmission in it a year ago. 15/41 gears it gets up and moves still and pretty fast. it does need a seat cover. i want to sell it so i can get a dirt bike. i love my banshee but i have more fun on a dirt bike. i may change my mind still. i would be interested in a trade for a dirt bike or a car/pickup, let me know what you got. $2200.00 Chevshee
exhaust burnin air filters
chevrolet banshee replied to chevrolet banshee's topic in Jetting & Exhaust Forum
I guess i dont understand how you zip tie k&n filters? they are melting from touching them and smashing a good set of filters just dont make sense to me. I burn spark plug wires on my pickup alot thats why i was gonna get the header wrap, and just cut off a chunk for my banshee. but rocky mountain sells heat shield, i don't know if that would work it might melt the glue if i stick it on my stingers? -
need help with next mods.
chevrolet banshee replied to bakersfieldturbo's topic in Banshee Repairs and Mods
Also if you wanna go faster try light weight parts like aluminum stuff, and traction, tires and sprockets, just junk that will make a little bit of a difference. Chevshee -
it lets the motor rev faster, I think. i have never had one or messed with one but from my understanding thats what it does. i think its more of a trail thing. Chevshee -
Lightened flywheel lets the motor spool up quicker and all that junk. Chevshee oh and i payed $300 for my carb's throttle cable and jets, 25 for air filters, 125 for the boss intake. -
I would grab a boss intake and a set of 35mm pwk's, that will get you some more air. thro on some k&n pods to, just watch out they might melt. do that and run the fancy spark plugs. chevshee p.s dont for get the boost bottle. -
I think I'm gonna buy some of that header wrap, wrap my headers and do my banshee exhaust. its 50 bucks a roll at shucks but its worth not having to buy air filters and spark plug wires every other ride haha. Chevshee -
So what could i put on my exhaust pipes to keep my air filters from melting? Any help would be great. Thanks Chevshee
I think that will help, alot. but if anyone has any ideas let me know. thanks Chevshee
Sup, can someone find me someone who makes a throttle cable for dule keihin pwk's and a twist throttle? It's a YZ style twist throttle if that helps. i cant find one. thanks Chevshee
Any head the uses a prodesign dome, like noss head. i think anything under a 19 or 20mm head you want to run a high octane fuel. it depends on your starting compression. Im not sure about the horse power gain but i think its between 0 and 10. :shrug: Chevshee
A shift star would be pretty simple to do if you have some simple hand tools and a 32mm socket for the clutch. All you need to do is drain your fluids and take off the clutch cover. then take off the clutch. be sure to remember how it came apart, in the proper order. take out the kick start gear and the shift shaft. then you'll be able to see the shift star, take out the old one give it to me, and put in your new one. reassemble and have fun. Chevshee
I think cascade makes a pretty good one, I don't know for sure tho. Chevshee
I have a friend with a 2003 yz250, not stock buy any means. i think it had v-forse 3 reeds, jetted, fmf gnarly pipe and silencer, and maybe a K&N filter. 4 out of 4 times i won. he got me off the start but i would walk buy him. and it was about the speed of a walk difference. i know my banshee goes pretty fast but i don't know compared to like a 450 or 700. I would say that's pretty good tho. Chevshee
found it!!!! Red is boost bottle and blue is stock. Chevshee
terrible machineing
chevrolet banshee replied to thehillsiderider's topic in General Banshee Discussion
Ok ya that makes sense. ya thats what i wood do, that wood fuck them if they wear the same and the bore was different. Chevshee -
terrible machineing
souds like he said that the cyis. wear bored too different sizes. i just want to know how hat happens? some one in that shop that did your cylinders is retarded. Chevshee -
The Banshee is running but!
chevrolet banshee replied to gclark63's topic in Banshee Repairs and Mods
If it constantly burs a lot of oil on the right side and you foul plugs on the right side your crank seal might be leaking or your cases may not have sealed. your jetting sounds rich try dropping the pilot down a size or to. start at 1 turn out on the air skrus. hope i helped Chevshee -
Banner for Austins New Company!
chevrolet banshee replied to Bansh-eman's topic in General Banshee Discussion
that's funny!! I seen a reed made out of a pop can one time, it didn't work i don't think. :shrug: Chevshee -
sweet man i love winning races, fun stuff right there. Chevshee
That's the weirdies thing i have ever heard of, I wood do like dsmrx7 said and check your bearing. Dose it look like that right cyl burns oil or something? and dose you oil level go down in your trans after a ride? Chevshee
