drag shee Posted November 28, 2006 Report Posted November 28, 2006 IF YOU CAN HELP WHAT IS THE BEST MIXTURE RATIO FOR RUNNING ALCOHOL AND THE BEST OIL FOR IT PS .SOMEBODY SAID THAT IT MIXES JUST LIKE GAS THANKS Quote
kubiac3 Posted November 28, 2006 Report Posted November 28, 2006 Im not sure on the mixture, but im pretty sure an oil made by klotz is the only oil you can mix with alcohol, well that ive seen. Im not sure on the name of the oil is. Im sure its on klotz website. Quote
sheefreak Posted November 28, 2006 Report Posted November 28, 2006 A good straight castor oil(927, Benol, etc.) 24:1. Quote
lowriderb Posted November 28, 2006 Report Posted November 28, 2006 927 and benol are the common ones.. the ratio we usually run is like 32:1 Quote
badassbanshee479 Posted November 28, 2006 Report Posted November 28, 2006 I am running super tecnaplate at 32:1 Quote
NYUK Posted November 28, 2006 Report Posted November 28, 2006 i ran 927 at 40 to 1 .never had a problem. Quote
jankab Posted November 29, 2006 Report Posted November 29, 2006 IF YOU CAN HELP WHAT IS THE BEST MIXTURE RATIO FOR RUNNING ALCOHOL AND THE BEST OIL FOR IT PS .SOMEBODY SAID THAT IT MIXES JUST LIKE GAS THANKS 28/1 Klotz Benoil Quote
alcoholbanshee Posted November 29, 2006 Report Posted November 29, 2006 927 at 40:1....never had a problem either. Quote
Malott 1 Posted November 29, 2006 Report Posted November 29, 2006 Benoil 32-1. Then I purge that day with 16-1 benoil/gas. Quote
Aaron.D Posted November 29, 2006 Report Posted November 29, 2006 Benoil 32-1. Then I purge that day with 16-1 benoil/gas. Sick Beast man.What about using an Ester blend. You guys are talking about the 927. Would an Ester blend work? MAD Quote
JaysonP Posted November 29, 2006 Report Posted November 29, 2006 i would just run 32:1 depending on whatmods your motor has, squish band, compression ratio(PSI) etc etc... seeing that Alki doesnt combust, it just kinda flames out and rolls making a smoother revolution, and burning cooler but atleast 40 Quote
