herbanshee Posted October 3, 2006 Report Posted October 3, 2006 Well, you guys were oh-so-helpful on getting my stapped off screw out of the housing.........worked like a charm! So now Im putting it all back together and cant hold the housing tight enough without it turning to torque down. I was thinking of using a screwdriver as a wedge, but I figured that was asking for something to get jacked up. Do you need a special tool or is there another trick-of-the-trade? Quote
hotrodbanshee Posted October 3, 2006 Report Posted October 3, 2006 Put it in 1st gear and lock the parking brake. Quote
okbeast Posted October 3, 2006 Report Posted October 3, 2006 Hmm we did the screwdriver trick on my buddy's blaster and shee. Guess we got lucky not breakin anything. Quote
djackbanshee Posted October 3, 2006 Report Posted October 3, 2006 (edited) Ive already seen a homemade tool made of an old steel cluth plate with a handlle welded on to it , just hold the handle and tighen the hub. Never hold it with a screwdriver the little (fingers) are very fragile. Edited October 3, 2006 by djackbanshee Quote
Bansh-eman Posted October 3, 2006 Report Posted October 3, 2006 either i cant read or what? are you talking about in inner clutch hub? if so theres a tool kinda like a reversed vise grip tha holds it if not then im retarded and read your post wrong... Quote
BigRed350x Posted October 3, 2006 Report Posted October 3, 2006 I made a tool for the next time I go to do this... Welded a fiber plate and an inner steel clutch plate together. Locks the inner and outer hub together. He He! Quote
pipebomb Posted October 3, 2006 Report Posted October 3, 2006 get yourself a clutch holding tool or "Grabbit". they will make your life much easier and safer. here's the one I got. paid a bit more at the dealer for it but was worth it. *Made from medium carbon steel with hardened jaws *Hold clutch hubs, flywheels, gears, sprockets, etc. *Features 8mm spanner pins *Jaws open up to 5 inches wide Quote
dawarriorman Posted October 3, 2006 Report Posted October 3, 2006 I made a tool for the next time I go to do this... Welded a fiber plate and an inner steel clutch plate together. Locks the inner and outer hub together. He He! Best idea I've heard, and cheap tool. While I never mind having more tools, I don't really want to have to buy one that Im never going to use. I just took 2 pieces of angle iron, and made my own tool. Quote
fastcar01 Posted October 7, 2006 Report Posted October 7, 2006 I think I read it here, use a penny in the gears. It is soft enough that it will give before the gears, but you will torue it to spec before that point. I think last time I did it I shoved a rag in the gears. You can just hold the brake and put it in gear,but that it easier with two people. Quote
herbanshee Posted October 7, 2006 Author Report Posted October 7, 2006 Got it, thanks guys! :beer: Quote
Ducman Posted October 7, 2006 Report Posted October 7, 2006 I'd just put it in gear, and if its the clutch spring bolts, I would just hand tighten it with a small closed end wrench. Those things are darn easy to snap off using a torque wrench that has a 12"+ handle. Quote
