Rebel3190 Posted July 25, 2006 Report Share Posted July 25, 2006 Im in the process of rebuilding the top end on my shee and the pistons weren't marked as to which one went with which cylinder does this matter? Quote Link to comment Share on other sites More sharing options...
DRI4life Posted July 25, 2006 Report Share Posted July 25, 2006 no it doesnt matter.. just make sure they are facing the right way.. Quote Link to comment Share on other sites More sharing options...
JUGGS Posted July 25, 2006 Report Share Posted July 25, 2006 No man it don't matter just make sure the arrow's are pointing at the exaust port of the jugg. Quote Link to comment Share on other sites More sharing options...
bansheeryder21 Posted July 26, 2006 Report Share Posted July 26, 2006 I learn something new every day!!! Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted July 26, 2006 Report Share Posted July 26, 2006 hmm id have to disagree here..everytime i have ever had cylinders bored they wanted the pistons. when i got the cylinders back they were marked with a 1 and 2 so id get the pistons in the right hole. a couple of these times were from reputable builders also...take it for what its worth. i guess if they werent marked then go ahead... Quote Link to comment Share on other sites More sharing options...
blueshee03 Posted July 26, 2006 Report Share Posted July 26, 2006 hmm id have to disagree here..everytime i have ever had cylinders bored they wanted the pistons. when i got the cylinders back they were marked with a 1 and 2 so id get the pistons in the right hole. a couple of these times were from reputable builders also...take it for what its worth. i guess if they werent marked then go ahead... i'd have to agree with you loco to a certain extent.alot of builders do bore according to the piston and mark which piston they bored which cylinder for.however alot of builders on the other hand don't mic the pistons indivually when they bore the cylinders.as a rule the pistons are the same or close enough that it dont matter.in rare instances there has been a pretty significant difference in piston specs even though they are supposed to be the same. Quote Link to comment Share on other sites More sharing options...
bansheeryder21 Posted July 26, 2006 Report Share Posted July 26, 2006 i'd have to agree with you loco to a certain extent.alot of builders do bore according to the piston and mark which piston they bored which cylinder for.however alot of builders on the other hand don't mic the pistons indivually when they bore the cylinders.as a rule the pistons are the same or close enough that it dont matter.in rare instances there has been a pretty significant difference in piston specs even though they are supposed to be the same. So what you're saying is that on a stock motor it doesnt matter wich one goes where, but on a bored motor, they have to marked for the right cyclinder? Quote Link to comment Share on other sites More sharing options...
Polish Posted July 26, 2006 Report Share Posted July 26, 2006 hmm id have to disagree here..everytime i have ever had cylinders bored they wanted the pistons. when i got the cylinders back they were marked with a 1 and 2 so id get the pistons in the right hole. a couple of these times were from reputable builders also...take it for what its worth. i guess if they werent marked then go ahead... I thought the same thing ...............when I got my motor back the pistons were marked for each cylinder...................I have never taken apart a stock shee motor to replace it back to stock.......always had it ported/pistons to match........ :thumb: Quote Link to comment Share on other sites More sharing options...
Rebel3190 Posted July 26, 2006 Author Report Share Posted July 26, 2006 mine pistons are weisco i didnt see any arrows but my buddy out em on and he does this shit all thhe time. Quote Link to comment Share on other sites More sharing options...
batoutofshell Posted July 26, 2006 Report Share Posted July 26, 2006 I have a owner of 2 strokes for 20 years it doesn't matter which goes where the stealerships and builders will tell you anything you want to hear so they sound technical,its up to you if you take all that bullshit in.I know better I have had to re-piston alot of 2 strokes in my past and it don't mean jack which side you put them in unless they are bored different sizes.they can mark them l/r or 1/2 whatever. Quote Link to comment Share on other sites More sharing options...
FasterThanU90 Posted July 26, 2006 Report Share Posted July 26, 2006 When havin Cyl. Bored out to the next size say u get pistons for a .20 bore out of the box there not gonna be exactly the .20 over bore that was done on your Cyl. yah thell work but to get the best performance/top end life like Tyler & Blueshee brought up, a good shop will match the pistons to the bore size and thats why theyd be marked Quote Link to comment Share on other sites More sharing options...
nitroburner13 Posted July 26, 2006 Report Share Posted July 26, 2006 When havin Cyl. Bored out to the next size say u get pistons for a .20 bore out of the box there not gonna be exactly the .20 over bore that was done on your Cyl. yah thell work but to get the best performance/top end life like Tyler & Blueshee brought up, a good shop will match the pistons to the bore size and thats why theyd be marked definetely agree that matching is the way to go. i had a top end done my jerry hall about a year ago and i ride every week. compression is still at 170 pounds and there is not a single scratch in either cylinder. Quote Link to comment Share on other sites More sharing options...
racer Posted July 26, 2006 Report Share Posted July 26, 2006 i agree with tyler also. it matters if you have them bored very closely. but who knows? i got 215 psi out of 19cc domes when i had mine bored like this. :baseball_bat: Quote Link to comment Share on other sites More sharing options...
BANSHEEMANIA Posted July 26, 2006 Report Share Posted July 26, 2006 I agree that it only matters if the machine shop took the time to measure both pistons before he bored the cylinders. If the shop just did a general rebuild and wasn't worried about optimum performance than it doesn't matter which hole they go in. My shop had to have both pistons in hand before he would bore the cylinders. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted July 27, 2006 Report Share Posted July 27, 2006 I've always had them mark the pistons. I bet it would be rare for two pistons to be absolutely identical. The piston's blueprints allow a tolerance in either direction for cirumference. But, you may not notice any difference if you don't mark them, b/c the pistons may be so close it won't matter. Just my 0.02. Quote Link to comment Share on other sites More sharing options...
