Hey guys,
I was changing my water pump when a bar fell out of the outer crank case. It is not the one that make the pump spin with the gear. it is about a third smaller.. any help would be appreciated.
Just a guess but, thats not that little pin that rides on the POS plastic gear that drives the water pump is it??? Kinda hard to see exactly how big it is.. Take a pic of it by a nickle or somethin..
RIPPEN
Edited by RIPPEN
No it is not the pin from the gear. here is another shot.
I'm going to have to pick this one up when I get back. Thanks for the help. Got a widespread panic show to go to in LA. Thanks guys!
just my contribution
its called a " pin dowel " they are 86 cents from riva yamaha ,
here is the link
http://216.37.204.203/Yamaha_OEM/YamahaATV...pe=13&A=208&B=4
Click that link, select your year, and model , and then go down to cooling system underneathe the engine tab. From there you can see a water pump break down aswell.
Enjoy
COOL, now where does it go!
It goes in your shift segment and shift drum.If you look just underneath your clutch basket and to the left you'll see your shift segment it's the dowl for that.
