Everything posted by watkins
Well, the arm does not move up and down.. So.... I am totally off on this one... if he lost all tension and that was that then I would say OK probably the internal adjuster came out. But that as he was limping it back to camp that all tension came back and it started working fine only to have it crap out again... thats messing with my mind.
I am helping a buddy with my old banshee that I traded him... Anyways he is saying that when he was riding it the other day all of a sudden there was no tension on the clutch lever what soever and that he could move the clutch actuator arm with his fingers with no resistance.... Ok my first thought it the adjustment screw broke loose, but then he tells me he is able to get the bike moving and then 5min later it starts working again and then about 5 min after that the tension goes away.... I have not yet seen the bike but my only thought would be that the little clamp that holds the actuator arm down in the case came off and the arm is able to move up and down.... Any other ideas? I would definitely think it to be an internal issue but what has me thrown for a loop is that it is intermittent. He will be looking at the bike later tonight just wanted to see what everyone else thought.. Strange.
PM sent
I will think about it. Do you have any pictures? I am really looking for a YZ250 (not the F), CR250R or CRF450 though.
Price reduced to $2900 can't go lower or Trade for a YZ250, CR250, CRF450.
Ok here is the only picture I have on me right now of the motor (at work right now). This was taken 3 months ago after a full rebuild. It literally has 1 hour on it. PM me with serious offers on the motor. If I get enough interest I will part out the rest of the bike. http://picasaweb.google.com/lh/photo/IBtzo...feat=directlink
Here are some quick shots. If I can get some interest in the motor I will break the bike down and post pics of everything. Just dont want to tear into it quite yet if there is no interest. http://picasaweb.google.com/lh/photo/sld8j...feat=directlink http://picasaweb.google.com/lh/photo/K6qs8...feat=directlink http://picasaweb.google.com/lh/photo/tPwmW...feat=directlink
Any interested in me parting this out? I'd rather sell it whole but if there is interest I may part it.
2001 Yamaha Banshee Duner Green Sticker. 3500 OBO. Willing to trade for Dirtbike. Bike was purchased brand new from the dealer in 2004 (even though its a 2001, dealer had this puppy hiding in storage). Motor: Passion Racing 12-Port Long Rod Stroker CoolHead Billet Intakes V-Force3 Reeds 35mm PWK Carbs with K&N Pod Filters High HP Clutch Pancake Bearing Shearer Inframe Drag Pipes Billet Impeller Body: Tag T2 Handbars ASR Clutch Lever Pingel Dual Output Fuel Valve Steel Braided Throttle Cable Trail Tech Lights Casesaver Coolant Temp Gauge. Tires: Comes with a set of Holeshot Knobbies (front & rear. rear leaks air just a little, but stays full all day) Comes with 10-Paddle Haulers in the rear (almost brand new) Comes with a set of Sandstar front's.(front leaks air just a little but stays full for a weekend trip) Fresh pistons & rings. Starts first kick. NOTE: Must run on race gas ONLY. I have only put VP C12 through this motor. I used this bike as a duner, but built the motor as a dragster. NOTE: Subframe is bent due to the bike being rolled once. Everything works perfect just looks a little funny See ad for pics: http://sandiego.craigslist.org/esd/mcy/1061104098.html
Bike starts and goes but does not go over 15 m/h,
watkins replied to Arysal's topic in Banshee Repairs and Mods
How old is the gas? Do you still have TORS intalled? Also, the gas leaking would be due to a stuck float bowl. Take the butt and of a screwdriver and tap the bottom of both carbs (no need to take them off the bike). That should fix the leaking. -
Well.. pulled the reeds out.. everything looked fine... except..... on the right side there was a good sized flake of yamabond sitting on top of one of the petals... cleaned the reeds put it back together.. what do you know.. its smoking a bit now out of the right side. So... could the yamabond have weighed down the reed enough that at idle it couldnt open but allow it to open at 1/2-WOT? Not sure how it was sitting on there not being sucked into the motor.. didnt take much to pull it off.
Right side plug is wet if I pull it after idle.
These are not stock carbs.. these are PWK's.. L/R side doesnt matter.. no choke tube either.
Checked the reeds... While looking down the intakes with the carbs off, the right side (one not smoking) seemed to burp back fuel (very small amount) when moving the kick starter by hand.. Pulled the intakes, on the right side some of the petals had small (grain of sand) sized pieces of metal under them from a previous blow out so they were unable to close all the way.. maybe. Think this could have been it? I havent started it yet.
Could this be a reed issue or anything? Like I said I swapped left & right carbs and that didnt help.. so i dont think it has anything to do with that.. adjusted the carb tops.. so they are in sync really dont know what else to do besides start tearing the motor apart.
Check Carb Sync.. Waaay outa sync (left side was screwed out almost all the way) ... Sync'd them.. started the bike.. still.. no exhaust out the right side. Any other ideas to check? On a side note.. at WOT should the slides be visible at all or should they be all the way up? When I go WOT the slides still hang down a little bit...
Crank seals were replaced.
Hi All, Just finished a full teardown/rebuild and seem to be having an issue. The bike starts first kicks and seems to idle fine. However at idle the left side seems to be smoking pretty good and the left side has no smoke coming out whatsoever. The left side pipe also gets warm while the right does not. Now if I rev the bike a small amount of smoke comes out the right and if I ride down the street the bike pulls like a bat out of hell.... so it appears its running... I have swapped carbs thinking it may be a clogged pilot jet but that didnt do anything. Compression test shows both cylinders around 210PSI. Drained gas tank and put in fresh gas. Swapped plug wires. Now the bike always smoked a little more on one side, however there is no smoke out the right side and the pipe doesnt get warm at idle. Any ideas?
I am considering selling my new build.. what do you thinks its worth? All mods are listed in the sig... Frame is twisted. Comes with 10 Paddle Haulers and Holeshots knobbys.
Just finished a complete teardown and am having some shifting issues. It seems like my shift shaft has a little side to side play in it. When trying to downshift my shift shaft is able to slip past the nubs on the shift star. Now if I pull out (away) on the shifter while i down shift everything is perfect... make any sense? Its almost like something needs to be applying pressure to keep the shifter against the shift star... and by play we are talking 1-2mm... very small amount any thoughts??
Actually... LOL you have seen it. Jim @ Passion Racing sent it to you about a year ago. You actually sent it back to me with a new bottom piece of the head, you also cut new domes and sent them as well... Thanks for the tip the other day about the washers.
I want to buy a stock flywheel and stator. I also need the hardware that mounts the stator to the stator plate.
1. I remember when RS use to have good product. 2. How much for your flywheel? 3. The crank is pretty much brand new. Maybe 15hrs on it. Its a Wiseco Hot Rods Crank. Still think it needs to be replaced?
