I figured it would help a little but not as much as 10 km/h like me friend was saying..do you guys just use a jig saw to cut them?
455448[/snapback]
Tin snips work great. used them to cut plastics when i put t-6's on. easy to control and cuts smooth. still clean up cuts with sandpaper if needed. theres all different styles of snips so use whichever will work best for your cut. :rotflmao:
The actual gain is 2 mph or 3.2 kmh.
Yea ill probably just use my jigsaw, then sand down the edges and scratches
Hopefully it will turn out nice :cheers:
i actually used a utility blade with a new razer... and that worked great.. a little harder but the cuts were smooth and if i sliped i didnt hack off what i didnt want to like i would have with a jig... i would just a slower cutter than a jig that way yu can easily follow the lines and stuff.. also its a good idea to mark where you want to cut with a marker... then you have a line to stay by
456613[/snapback]
A utility knife is sharp/strong enough to cut the plastic, maybe ill use that then, and yea i was going to draw lines so i know where im cutting, did you have to sand the edges when you were done or did it do a good enough job
Edited by Dinner
All good ideas :headbang: ...yea i think im going to try the utility knife, and if i cant seem to get that to work, ill use a hacksaw, and sand it down
Use electrical tape.  You can place and replace.  leaves no residue/sticky stuff and it bends to make a curve.
456814[/snapback]
Did you just use the electrical tape as your lines, or did you put the electrical tape down, then followed that with a pencil/marker..sorry for all these questiongs just dont want to hack it up too bad :cheers:
Did you run your friend on his Z400? You should be able to smoke him and then he will quite down :D
458120[/snapback]
Not yet, sometime though :cheers:
