Shee-Male Posted January 18, 2006 Report Posted January 18, 2006 If you want the highest quality plug then go with BR8EIX. I don't know why someone here said to use a BR9EIX, as that is the wrong heat range; the 9 in that string of number/letters signifies the heat, and the higher the number the less the heat; it is supposed to be BR8 not BR9. BR8EIX is the best plug I know of, and they run about $8.00 or so. The IX at the end stands for being IRIDIUM. 437613[/snapback] Damn skippy, I've had great luck with these and I also find a noticable response, so far 2 years on them, fouling has everything to do with your jetting/tuning. Quote
RIPPEN Posted January 18, 2006 Report Posted January 18, 2006 b8egv is a good platinum plug t o run . it has a nice spark and resists fouling in low rpm conditions ,my.02 436414[/snapback] Thats the same plug I run for that exact reason. Pay a few more bucks but they seem to last quite a bit longer RIPPEN Quote
chris642 Posted January 18, 2006 Report Posted January 18, 2006 this is a little off topic but i heard this from someone on this forum and they said if you let your banshee idle for too long it will foul the plug. my freind lets his banshee idle for a minute, minute and a half no problem. also i never fouled a plugt at idle and i let my engines sit and idle for a period of time. thanks in advance for replys 460994[/snapback] As long as your machine is in tune you wont have a problem, i let my banshee idle for 5-6 mins for a warmup and it never has fouled a plug. Come to think of it, it NEVER fouls a plug!! My old Rm 250, on the other hand, would always load up if i would let it idle for more than 2 mins or so, it was a little rich though. Quote
sheenut05mx Posted January 18, 2006 Report Posted January 18, 2006 I run a BR8EG with the qround strap cut back just past the electrode Quote
sandman4free Posted January 18, 2006 Report Posted January 18, 2006 I just noticed that my builder does recomend the BR9EIX, I am guessing it reduces the heat in the combustion area helping to reduce some detonation. Quote
greg_banshee Posted January 18, 2006 Report Posted January 18, 2006 BR8EIX ! NGK Iriduims ! best plug out there i have run mine for almost 2 season now & still work great ! Quote
dawarriorman Posted January 18, 2006 Report Posted January 18, 2006 I just noticed that my builder does recomend the BR9EIX, I am guessing it reduces the heat in the combustion area helping to reduce some detonation. 461139[/snapback] No. The spark plug can't change or influence how much heat is in the combustion chamber. The heat range is for how hot the PLUG stays. A hotter plug has more insulation to hold in more heat, while a colder plug has less so the heat can escape. You use the wrong heat range, and you either foul a plug, or burn it up. Quote
bansheeigo Posted January 19, 2006 Report Posted January 19, 2006 The BR8EIX is the best plug but i used a NGK B8EV back then,it was a bad ass plug,too bad they don't make them anymore . Quote
2003LimitedBanshee Posted January 19, 2006 Report Posted January 19, 2006 No. The spark plug can't change or influence how much heat is in the combustion chamber. The heat range is for how hot the PLUG stays. A hotter plug has more insulation to hold in more heat, while a colder plug has less so the heat can escape. You use the wrong heat range, and you either foul a plug, or burn it up. 461195[/snapback] Kinda sorta... You've got it pretty much right on the plug heat range. A "hotter" plug has more insulation, ie. it holds more heat (just as you said), whereas a "colder" plug has less insulation, and disipates heat more quickly. The problem with running too "hot" of plugs is that the plug itself could actually retain enough heat to cause pre-ignition ("ping"), independent of the controlled burn ignited by the spark. Typically, you will want to run "colder" plugs as you increase the compression ratio (ie. more cylinder temperature) so that you decrease the chance of "ping". This is also the reason for running race fuel with higher octanes, as the octane rating signifies the resistance to combustion. Most times people will run hotter plugs because the engine is not running properly (4-stroke burning oil for instance) or the do not have the machine jetted properly. The "hotter" plug resists the oil accumulation more than the "colder" plug. Quote
dawarriorman Posted January 19, 2006 Report Posted January 19, 2006 Kinda sorta... You've got it pretty much right on the plug heat range. A "hotter" plug has more insulation, ie. it holds more heat (just as you said), whereas a "colder" plug has less insulation, and disipates heat more quickly. The problem with running too "hot" of plugs is that the plug itself could actually retain enough heat to cause pre-ignition ("ping"), independent of the controlled burn ignited by the spark. Typically, you will want to run "colder" plugs as you increase the compression ratio (ie. more cylinder temperature) so that you decrease the chance of "ping". This is also the reason for running race fuel with higher octanes, as the octane rating signifies the resistance to combustion.Most times people will run hotter plugs because the engine is not running properly (4-stroke burning oil for instance) or the do not have the machine jetted properly. The "hotter" plug resists the oil accumulation more than the "colder" plug. 461623[/snapback] Exactly, I just didn't feel like going into that detail. Quote
shanYE west Posted January 28, 2006 Report Posted January 28, 2006 I use Champion N6YC they run great for me. Quote
greg_banshee Posted January 28, 2006 Report Posted January 28, 2006 BR8EIX's & make sure there solid caps so they don't screw off ! Quote
KpnitG Posted January 29, 2006 Report Posted January 29, 2006 BR9EIX Iridium best spark plug resist Fouling , better start etcc.... 436595[/snapback] Hands Down! I Bought mine over three months ago and there no joke! Quote
mnduner Posted May 11, 2006 Report Posted May 11, 2006 ngk the higher the number the HOTTER the plug i have some br10eg left over from my pig rich cr250 probably a bad idea? whats the diff between br8eg and br8es? thanks pete Quote
98bonerSTOCKshee Posted May 11, 2006 Report Posted May 11, 2006 As long as your machine is in tune you wont have a problem, i let my banshee idle for 5-6 mins for a warmup and it never has fouled a plug. Come to think of it, it NEVER fouls a plug!! My old Rm 250, on the other hand, would always load up if i would let it idle for more than 2 mins or so, it was a little rich though. 461021[/snapback] same here... NKG B8ES...... Quote
