sheenut05mx
About sheenut05mx
  • Birthday 11/24/1983
Contact Methods
    Elba NY
    05 shee, orange frame,black plastics, Ducan racing seat cover and graphics kit, DG nerfbars & bumper X5 bars, MXR4 and MX front , adjustable upper arms, 2.5'' front wheel spacers, no air box lid, FMF GOLD serries pipes. Custom +4'' extended swingarm, prodesign meaga flow water impeller.
sheenut05mx's Achievements
  1. how is the low end does it want idle clean or will it load up and foul plugs? You shouldn't need a 27.5 pilot at 900ft for just reeds. I run a 22.5 pilot and 1 clip higher on needle and a 270 main
  2. I wouldn't run any thing over 155psi 10.5:1 static, any thing higher and you'll want to run 116 octane.
  3. What do you quys think of the new shee?
  4. It appers that on the top of the head just off the squish band there is a hole burned in the head gasket surface? Anyone see the same thing?
  5. here is some more pics
  6. Flow?
  7. Yea I'll get some pics soon I am waiting on my buddies dig. camera. Working on it today Animalman294 What are you doing with the maching dunes only and what is you weight?
  8. Hey waz up guys how many of you use a extended swing any one looking for one? I just put a +4 on mine a is is f... awesome. It is a stock swingarm with +4 added in behind the shockmount. If any of you are interesting in doing this to yours let me know and we can work somthing out. CHFAB did all the work and you can't even tell where he added it in.
  9. Is the piston forged or casted? Do you have and calipers to measure the piston?
  10. The head gasket leak may have caused the detontion. I would defently check a little farther in to it. As far as water pump and jetting.
  11. I agree with FASTBANSHEE4U. Leave the stock carbs and do some suspension mods and you'll notice a lot more gain than you would with more engine mods. The stock machine cant handle and use the power that the engine has stock.
  12. It is most likly not the choke. Is the kicker not engaging half way through? What did the reeds look like when motor way rebuilt? What jets are you running? Did you remove everything from the carbs when you cleaned them.
  13. Definently some detonation. Has is been running hot? I would checK the waterpump imperller for damage or gear being stripped. Also it may be a little on the lean side because with stock compression being 6.5:1 there should defenetly not be detonating.
  14. I wouldn't mill the head more than .025'' any thing more and you'll want to change the sqwish band. I.'ll need some more info from you to figure out the compression email if you want some help. ([email protected]) 50 50 mix of turbo blue and 94 pump.
  15. How do the plugs look? Have you done a plug chop? Most likily what is causing the temp, to differ from pipe to pipe is one cyclinder is a littler richer or leaner than the other, causing temps to vary on that pipe. Change Idle air screws independenly of one another the seting will varity. I would also raise you main jet a few sizes depending on how the plugs look.
