quad4me Posted February 2, 2005 Report Posted February 2, 2005 (edited) Anyone know what size socket the drive sprocket NUT takes? I am putting on a 13 tooth gear...want to make sure I have that larger socket size! Edited February 2, 2005 by quad4me Quote
quad4me Posted February 2, 2005 Author Report Posted February 2, 2005 32, 33 or 34 one of those 316070[/snapback] OK..I have a 98'..if that matters Does anyone know for SURE what size? My larger tools got taken from the house..now I dont have the one i need...so i must go get it. I don't want to get the wrong one! Quote
bigboybanshee Posted February 2, 2005 Report Posted February 2, 2005 I think it's a 24mm but am not 100%. Hell I just changed my sprocket the other day, you'd think I could remember that shit Quote
PUSH THE THROTTLE Posted February 2, 2005 Report Posted February 2, 2005 (edited) I've been using a 1 1/4 socket on mine so thats a approximately a 32mm. Edited February 2, 2005 by PUSH THE THROTTLE Quote
banshdog Posted February 2, 2005 Report Posted February 2, 2005 I've been using a 1 1/4 socket on mine so thats a approximately a 32mm. 316282[/snapback] Just changed mine too, that sounds about right. Quote
bigboybanshee Posted February 2, 2005 Report Posted February 2, 2005 lol, damn I was way off... Quote
bansheeryder21 Posted February 2, 2005 Report Posted February 2, 2005 I think it's a 24mm but am not 100%. Hell I just changed my sprocket the other day, you'd think I could remember that shit 316277[/snapback] I am putting on a 13 too. Is it hard to change? What are the exact steps for changing a sprocket? Can I use the same chain? First time changing my sprocket! Please help me out!!! Quote
05bansh Posted February 2, 2005 Report Posted February 2, 2005 (edited) I've been using a 1 1/4 socket on mine so thats a approximately a 32mm. 316282[/snapback] Same here. As for installation its way easy! Remove your stator cover, unbend the washer on the nut on the sprocket, take the nut off, slide the old sprocket off, put the washer back on, put the new sprocket on, bend the washer over the nut, put the stator cover back on. and the funnest part- adjust your chain to accomadate your new sprocket! And yes, you can use the stock chain if you are putting on a 13 tooth. Edited February 2, 2005 by 05bansh Quote
bansheeryder21 Posted February 2, 2005 Report Posted February 2, 2005 Same here. As for installation its way easy! Remove your stator cover, unbend the washer on the nut on the sprocket, take the nut off, slide the old sprocket off, put the washer back on, put the new sprocket on, bend the washer over the nut, put the stator cover back on. and the funnest part- adjust your chain to accomadate your new sprocket! And yes, you can use the stock chain if you are putting on a 13 tooth. 316368[/snapback] How do I remove the chain??? I never done any of this before, that's why I'm asking! Quote
05bansh Posted February 2, 2005 Report Posted February 2, 2005 You dont need to remove the chain. You can get the factory sprocket off without touching the chain. You dont have to mess with the chain until you have the smaller sprocket on, then you will be tightening the chain. Damn! I just said chain a lot! Quote
bansheeryder21 Posted February 3, 2005 Report Posted February 3, 2005 You dont need to remove the chain. You can get the factory sprocket off without touching the chain. You dont have to mess with the chain until you have the smaller sprocket on, then you will be tightening the chain. Damn! I just said chain a lot! 316481[/snapback] Thanks!!! Quote
quad4me Posted February 4, 2005 Author Report Posted February 4, 2005 OKOK..SO...how did you guys get that sprocket nut off? That MOFO is TIGHT. I guess it is impact wrench time.....it keeps spinning the tires while I try to bust it loose. I got the shee up against a wall so it won't roll....and it just rotates the tires...dammit. suggestions? Quote
banshdog Posted February 4, 2005 Report Posted February 4, 2005 Mine wasn't that tight. Did you bend back the locking washer that is bent over the nut? Mine was like that, dont know if yours is. Quote
