SouthernBanshee
About SouthernBanshee
  • Birthday 02/23/1976
Contact Methods
  • Website URL
    http://
  • ICQ
    Buenos Aires, Argentina
    94 Banshee, PTR Hi-Rev pipes, ported reeds cages, pro-flow filter and everything else stock
Recent Profile Visitors
1,140 profile views
SouthernBanshee's Achievements
  1. i cant find bel-ray oils here in Argentina. I will try with some honda hp trans oil 80w/85w. I think it will be all right. the motul transoil is 10w30... :shrug:
  2. Hi guys!! Im going to try some fzr1000 fibers in my banshee. Im using Motul Transoil at this moment with EBC HD clutch kit. Is it fine for the fzr1000 fibers? Thanks from Argentina! :beer:
  3. i love those pipes... They look like PT Mids. The bottom end is a really weak point with a stock motor but... they a hi revs. Adding some mods like timing advance, compression, reeds and lightened flywheel will help a lot. From mid to top they are awesome. Im very very happy with them. Later
  4. machine the outer diameter down to 123mm but be careful with the timing tabs... You can also machine the outside of the hub where the rivets are located here is a pis of mine... Later
  5. stock banshee = 104 links 520 o-ring chain Later
  6. im using 15/41 with my mods and i love it...bottom end is great and i want to see what happens with a 14/40 a milled head will help you a lot. Lightened flywheel with +4 timing advance will do it. These mods wont empty your wallet and help a lot. A smaller front sprocket will take a bit of your top speed off Later
  7. dont forget suspension upgrades. Power without control is useless
  8. Its all about money... definitly get the lightened flywheel (i like it a lot) ported reed cages or v-force for throttle response improve aftermarkey head with 20cc or 21cc domes Porting what about suspension (+2+1 a-arms and shocks)??? Later
  9. ive got ported cages with boyesen power reeds. The difference to stock is huge!!! you cant go wrong with that combo (i couldnt find TDR reeds here but a lot of people told me that they are way better for ported cages than other aftermarket petals) ...BUT.....no one with v-forces will say something wrong about them... later
  10. with those mods and tires the stock gearing (14/41) should be fine but it wont hurt trying 14/40 or even 15/40 good luck
  11. PTR Hi-Revs and i love them!!!
  12. i saw it!!!! congratulations Nicolas!! you have a really awesome banshee!!!
