Dopeman0012 Posted January 17, 2005 Report Posted January 17, 2005 (edited) my buddy and his raptor continously beats me on the pavement. i stay in front until about mid 6th gear then he just blows by me. i have K&N filters, 35mm Keihin carbs, Keihin jets, FMF Fatties, Power Core 2 silencers and run a 14 front sprocket. i 've thought about getting the cpi pipes but other than that, i cant come up with nothing. does any one no how i can get more top end without boring the motor? Edited January 17, 2005 by Dopeman0012 Quote
Bansheerider29x Posted January 17, 2005 Report Posted January 17, 2005 Dont bother boring it unless your going to bore a lot. just so u know .20=5cc so if you want a lot more power go with a stroke kit and a port job. Thats what i think but im not a pro. Quote
RNBRAD Posted January 17, 2005 Report Posted January 17, 2005 my buddy and his raptor continously beats me on the pavement. i stay in front until about mid 6th gear then he just blows by me. i have K&N filters, 35mm Keihin carbs, Keihin jets, FMF Fatties, Power Core 2 silencers and run a 14 front sprocket. i 've thought about getting the cpi pipes but other than that, i cant come up with nothing. does any one no how i can get more top end without boring the motor? 307730[/snapback] Your running 35mm keihin carbs why? I'm sure this is absolutely killing your power output. Way too big of carbs for your motor unless you have some major porting. Quote
cory vogrinec Posted January 17, 2005 Report Posted January 17, 2005 my buddy and his raptor continously beats me on the pavement. i stay in front until about mid 6th gear then he just blows by me. i have K&N filters, 35mm Keihin carbs, Keihin jets, FMF Fatties, Power Core 2 silencers and run a 14 front sprocket. i 've thought about getting the cpi pipes but other than that, i cant come up with nothing. does any one no how i can get more top end without boring the motor? 307730[/snapback] How's your jetting? Might want to do a plug chop and check it to make sure that its where it needs to be. Maybe a 15 tooth front sproket, if the machine can pull it. Just my 2 cents worth. Good luck. Quote
Banshee~ Posted January 17, 2005 Report Posted January 17, 2005 Your running 35mm keihin carbs why? I'm sure this is absolutely killing your power output. Way too big of carbs for your motor unless you have some major porting. 307741[/snapback] Yea that big of a carb wont help you unless you have the compression.Get a Noss Machine coolhead and some domes,reed cage,port your motor, and put in a stroker. Quote
cb67rs1 Posted January 17, 2005 Report Posted January 17, 2005 cut his fucking tires then ask him to race ,, you want have to spend shit on mods!!! Quote
bansheeboy619 Posted January 17, 2005 Report Posted January 17, 2005 think about toomey's I had FMF's on my old bike changed to T5's and was 100 times happier. Quote
1800bigk Posted January 17, 2005 Report Posted January 17, 2005 (edited) Definatley gonna need to get port job to get the most out of those carbs. Your buddies wont stand much of a chance if you get a good port job. Especially if you race them on pavement. oh I didnt notice that you said you can hang with them until sixth gear, I would just put 15 tooth front sprocket on then try. Edited January 17, 2005 by 1800bigk Quote
viperejt Posted January 17, 2005 Report Posted January 17, 2005 If you have on motor work then your carbs are to big. You may want to run open air filtes or try porting. You may even want to put your stock carbs on. Quote
H250RHATER Posted January 18, 2005 Report Posted January 18, 2005 (edited) get some 28 flat slides he wont be near u those carbs are way too big if u just have fatties on there no wonder why he's beating u Edited January 18, 2005 by H250RHATER Quote
FIRST BANSHEE Posted January 18, 2005 Report Posted January 18, 2005 my buddy and his raptor continously beats me on the pavement. i stay in front until about mid 6th gear then he just blows by me. i have K&N filters, 35mm Keihin carbs, Keihin jets, FMF Fatties, Power Core 2 silencers and run a 14 front sprocket. i 've thought about getting the cpi pipes but other than that, i cant come up with nothing. does any one no how i can get more top end without boring the motor? 307730[/snapback] sorry to hear that, but your stock carbs back on and you'll spank him,,, or get your motor ported to handle those carbs and he won't hang with you through first. also put a 15t in front. Quote
bansheeryder21 Posted January 18, 2005 Report Posted January 18, 2005 think about toomey's I had FMF's on my old bike changed to T5's and was 100 times happier. 307750[/snapback] What old bike????????? You can't trick me Rory!!! Quote
05bansh Posted January 20, 2005 Report Posted January 20, 2005 Do the port and he will not be able to touch you. And then you will getting the full benefit out of the 35mm carbs. Quote
2stroke_addict Posted January 20, 2005 Report Posted January 20, 2005 i think is an uphill battle, raptors have diferent gearing ratios, not to mention the 660cc's of displacement, i am afraid the raptor will still be faster despite your mods, but sure as hell you will be quicker. Quote
r6rider04 Posted January 20, 2005 Report Posted January 20, 2005 i used to spank my buddies raptor with my shee, mostly stock, pipes, reed spacers, k&n filter Quote
