Just thought about your set-up with the 34mm carbs, you probably don't have the stock type intakes, so you probably could not hook up the mamometer. You may have to visually check the sync. (carb slides) to see if its in the ballpark, not too accurate but if its REALLY out of sync. the visual will get you in the ball park. In a pinch, I've used SMALL drill bits to gauge the gap between the slide and carb. body.
