KiwiBanshee Posted October 9, 2004 Report Posted October 9, 2004 Hi there, Looking to get rid of my stock carbs have had a look around are the trinity 2 in 1s any good ??? Any other recommendations?? Cheers Quote
Banshee~ Posted October 9, 2004 Report Posted October 9, 2004 Yea alot of people on here have them...the give you tons of low end and you only have to jet once.I would recomend the 35mm. Quote
Leadfoot350 Posted October 19, 2004 Report Posted October 19, 2004 stick with two. Any high performance engine works better with one carb per cylinder. Look at ferraries, fast bugs, porsche's, they all have the same set up. One carb per cylinder gives you better low end and throttle response and top end. Quote
PUSH THE THROTTLE Posted October 19, 2004 Report Posted October 19, 2004 (edited) I'm all for the Trinity I won't get rid of mine unless I go to a stroker motor then I'll by another 35mm, boots, throttle cable and then I'll be ready. Do a search there's plenty of info about them. Edited October 19, 2004 by PUSH THE THROTTLE Quote
FIRST BANSHEE Posted October 20, 2004 Report Posted October 20, 2004 I think the trinity intake is awesome. compared to stock the power increase is incredible, with very little hesition on the bottom, a ton more power on top. Easier to tune, easier to start. If you have the normal bolt on's, go with the 35mm. If you do any trail ridding were there's water go with airbox adapter. If you mostly drag and dune ride go with the clamp on. Quote
Leadfoot350 Posted October 20, 2004 Report Posted October 20, 2004 ask any true motor builder and they will tell you they are junk. Quote
PUSH THE THROTTLE Posted October 20, 2004 Report Posted October 20, 2004 ask any true motor builder and they will tell you they are junk. Why do you have one then? Quote
Leadfoot350 Posted October 22, 2004 Report Posted October 22, 2004 I dont want to bother putting the stock ones back because they have the tors crap on so I am running it for now. I am going to get another 35 and sell the manifold when I get either a 4 or 7mm stroker. Ask Rudy kurts, mission yamaha, a&s,K&t, R.I.S. They will tell you dont bother. They are great for ease of use but for power they dont compair. Quote
FIRST BANSHEE Posted October 24, 2004 Report Posted October 24, 2004 I dont want to bother putting the stock ones back because they have the tors crap on so I am running it for now. I am going to get another 35 and sell the manifold when I get either a 4 or 7mm stroker. Ask Rudy kurts, mission yamaha, a&s,K&t, R.I.S. They will tell you dont bother. They are great for ease of use but for power they dont compair. those builders did'nt say they are junk, they said they don't make is much power, as dual 33or 35's. put your stock carbs back on,and i promise you you'll be alot slower. trinity cv intake with a 35 rocks Quote
Leadfoot350 Posted October 25, 2004 Report Posted October 25, 2004 which ones said they are not junk? Quote
banshee76179 Posted November 4, 2004 Report Posted November 4, 2004 If U r drag racing yeah dual r going to be better.. But, if U r into Trails,MX,XC and screwing around than 2-in-1 is the way to go.. And yes my builder sold me on it.... But, when I start boosting my HP up even more than I will eventually go to a dual setup...but, for now I will stick w/my 2n1.. just my 2cents Quote
Wassup350 Posted November 12, 2004 Report Posted November 12, 2004 stick with two. Any high performance engine works better with one carb per cylinder. Look at ferraries, fast bugs, porsche's, they all have the same set up. One carb per cylinder gives you better low end and throttle response and top end. 271158[/snapback] We arent talking about 4 stroke cars we are talkin about 2 stroke quads. I use to have dual carbs and they sucked. of course your not gonna gain high end power but who needs it? Most people need lower and midrange power, especially for MX. The 2 into 1 carb gives a bit more low end power so that you can come out of corners and not have downshift to first or second just to get back into the powerband. Quote
PUSH THE THROTTLE Posted November 12, 2004 Report Posted November 12, 2004 Leadfoot, I think that since you only ride at glamis duals(not stock) are the way to go since I assume you typically ride in the higher rpms. If you ride trails or anything were you are really utilizing the entire power range the single is perfect. I don Quote
toolman Posted November 12, 2004 Report Posted November 12, 2004 I have a single lectron and a dual setup.You might get more top end with duals but in the woods or a short drag race I wil take my single any day any time. Quote
theeechozen1 Posted November 13, 2004 Report Posted November 13, 2004 What size Lectron are you running?? Quote
