Shee_Rookie Posted August 16, 2004 Report Share Posted August 16, 2004 O.k. Well here it is... I have a all stock 2000 banshee with no mods .. Anyway I decided to check the compression in each cylinder and what I came up with is about 79 on the left and 75 on the right. Not sure if this is good with my elavation being at about 4200 ft? After this I put a brand new set of plugs, put in my clean spare air filter and new gas mixed at 32:1 and started riding. About five minutes into my ride the bike got real sluggish and an then just died. Was about a mile or so away from home and the damn thing would not start! When I would kick it over it would start for about 2 seconds and die again. Then after lettting it sit for about the length of a smoke, tried it again and nothing. Wound up pushing the bike home.. Got back and check the plugs and they looked good, not fouled out. There were no symtoms of poor performance before leading to this, any help would be appreciated. I'm thinking possibly TORS but once again I am a Rookie so any thoughts are welcome.. Quote Link to comment Share on other sites More sharing options...
banshdog Posted August 16, 2004 Report Share Posted August 16, 2004 I dont think that the TORS would cause the bike to not start. Your compression sounds low to me......anyone else? Quote Link to comment Share on other sites More sharing options...
LegendSS28 Posted August 17, 2004 Report Share Posted August 17, 2004 Your compression is way too low, its time for a new top end Quote Link to comment Share on other sites More sharing options...
BMackKC Posted August 29, 2004 Report Share Posted August 29, 2004 You definately need to rebuild your compression should be over 130 in each cylinder anytime it gets lower you need to rebuild. You should probably bore the cylinders because with compression that low your clearance between you cylinders and your pistons will be huge. That is what i was just told by my mechanic. Quote Link to comment Share on other sites More sharing options...
dlnoss Posted August 29, 2004 Report Share Posted August 29, 2004 At that elevation, I would think your compression should be around 105 Since it is pretty even, you might try a different guage with the engine hot holding the throttle wide open. Of course if it won't start it's difficult to get the engine warm. I hate to ask but does it have fuel and fire? When you figure out the problem, you could increase the elevation related lower compression with a shaved or aftermarket head. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted August 29, 2004 Report Share Posted August 29, 2004 Could be a bad stator or electrical. Quote Link to comment Share on other sites More sharing options...
Banchetta Posted August 29, 2004 Report Share Posted August 29, 2004 Like Dave and Rod said, check for spark. Did you just look at the plugs or put some new ones in? You can't tell by looking at them. Try some new plugs and check for spark and go from there. Quote Link to comment Share on other sites More sharing options...
banshee_kid350 Posted August 31, 2004 Report Share Posted August 31, 2004 man I would say that you need a new top end rebuild. I live at about 4500 feet above sea level and i just put a new top end on my banshee along with a noss head and 19cc domes and my compression is at around 100psi Quote Link to comment Share on other sites More sharing options...
PUSH THE THROTTLE Posted September 2, 2004 Report Share Posted September 2, 2004 man I would say that you need a new top end rebuild. I live at about 4500 feet above sea level and i just put a new top end on my banshee along with a noss head and 19cc domes and my compression is at around 100psi. That's really low after a rebuild and domes????? I've heard of people running them down to about 95psi as long as their the same. The important part is that they are the same. I think your not checking it correctly if your down at 75psi because to get down there it had to be running and below 90psi I don't think it would. Check it like Dlnoss said above. Quote Link to comment Share on other sites More sharing options...
DevilDriver Posted September 7, 2004 Report Share Posted September 7, 2004 time for a top end. mine did the same thing with the same simptoms. my comp was about 80-90psi at about sea level. after the rebuild it was 155 and it started up within 5 kicks. you may be able to cheat and go with new rings?? but id just bore it .020-020 and put some new pistons in it. you wont be sorry. Quote Link to comment Share on other sites More sharing options...
