i have a pair of pure sport bandits on mine and i love them, they are the xc's so there a heavier ply but theve been awsome tires ive had them for two years and can prlly go another one if i wanted.
i have the pure sport bandits also and love them,there ok for the snow. I only trail ride. Good grip uphill :cheers:
Razrs are great all around tires, but are kinda lacking in loose stuff like sand. I tried some Bearclaws when I first got the Shee and they worked great on everything. They're heavy though and 22" is the smallest size available.
shredders are alright on harder stuf but when you start to get into sand and soft stuff the patterns are too close togetheer to provide good hookup. not hte best tire for the awsome power of a banshee. i suggest razr or hole shots kendas wouldnt be a bad choice either
what do you ride more of, mostly road or mostly sand? If you ride road to get to sand then your want a good tire that works in the sand thats still road rideable to be able to get there. Now if you do a lot of back road riding, and go off into the sand about half and half your gonna want a different tire.
I'd recommend some 20" blackwaters. Check them out, have a good pattern to hook in sand, and arent to bad on the road. A little bumpy at low speeds but nothing to write home about kidney damage.
  • 2 weeks later...
I'm running stock tires and wheels right now, but will end up going to Razor 2's on Aluminium wheels soon ....hopefully. Have you all checked out the Gnarley design the Razors 2's have...DEEP X Lugs!!
I just saw the Razr2s for the first time last weekend. Holyman's right, the lugs are extreme. They are at least twice as deep as the originals. Those will probably be what I get next.
I HAVE A SET OF RAZOR 2'S ON THE REAR EXELENT TRACTION, U CAN STILL KICK THE ASS END OUT IF NEEDED! I LIKE THEM SO FAR, NOT THAT GOOD IF YOU RUN INTO SAND ON THE TRAIL.
I have a shee with holeshots and a shee with realtors and the hole shots hook up a lot better than the realtors but they are much softer, dont see them lasting too long.
