NJ Bansheeman 00 Posted January 17, 2004 Report Posted January 17, 2004 What will be a good sprocket sizes to for racing MX ? I'm running 18's on the rear now with a 15t front and a 40t rear . I figured i would ask because this coming spring i'm going to be running some district 6 races and some local mx racing also . I'm going to be doing a complete overhaul to the drivetrain ( front sprocket, rear sprocket ,chain slider, chain rollers and rear chain guide .So any information would be helpful . Quote
DIABLO BANSHEE Posted January 17, 2004 Report Posted January 17, 2004 if your bike is stock put the 42 on the back if you got mods use the 41 or 41,i run 15-41 at all the nor cal tracks. Quote
Blue Duece Posted January 18, 2004 Report Posted January 18, 2004 what are your motor and chassis mods?..... Quote
stu35 Posted January 19, 2004 Report Posted January 19, 2004 14/38 or 15/41 works great w/ 18". They result in the same ratio. Quote
banshee2sick Posted January 21, 2004 Report Posted January 21, 2004 What would be a good ratio to use for mx with 20" tires? Quote
Blue Duece Posted January 21, 2004 Report Posted January 21, 2004 What would be a good ratio to use for mx with 20" tires? id stay with a 15/41 until you get some horsepower then try a 16 or 17 up front Quote
stu35 Posted January 21, 2004 Report Posted January 21, 2004 In my opinion and experience, 15/41 is too high for MX. Just my thoughts and 6 years of racing. But - I run 14/38 (or 15/41 same thing) with 18" tires. For stock, or 20" tires, stock gearing is better (14/41). Depending on traction of the launch, I like to start in 2nd gear. With this high a ratio, this could not be done effectively with 20" tires. Some people prefer different set-ups but if you can launch good in 2nd, you will have a great shot at the holeshot. When all the other guys are shifting to 2nd, you are still on the power and flying by them. Quote
Blue Duece Posted January 23, 2004 Report Posted January 23, 2004 In my opinion and experience, 15/41 is too high for MX. yeah but your riding a stock bike......a 15 on your bike is like a 13 on mine.....sometimes you need to gear up...... Quote
bpreuss Posted February 7, 2004 Report Posted February 7, 2004 i have 14/40 on mine with alot of mods, it has good gitty up and go but will only do like 70 but for mx you dont need no more, what should i put on for freestyle? i bigger front for smoother power? Quote
sredish Posted February 7, 2004 Report Posted February 7, 2004 i run 15/41 with 20" tires. I run 20" tires because I ride a little xc also, and too cheap for different tires. Quote
DIABLO BANSHEE Posted February 9, 2004 Report Posted February 9, 2004 I did a little gear change for last weekends race in marysville ca,it's a tight track for the most part,anyways i was running 15/41 and i changed back to stock14/41 with 18inch tires.both motos i pulled 3rd(that's right 3rd)gear starts and killed everyone off the line,i didn't end up with the overall but this gearing allowed me to be on the pipe at all times,and was one of my fastest races yet.if your wondering about my motor work click on my sceen name. Quote
Torn66 Posted February 11, 2004 Report Posted February 11, 2004 the topic isnt even worth discussing until you know the following Track layout Mods Rider ability ...for the most part- banshee MX'ers ahev to re-gear more than any other bike since they have no low end (even with low end mods) I know i have to run 2 completely different gearings for Jack Frost and Rausch Creek to practice because the track is so different. (i wish i remebered what the combos where though!) tight tracks with jumps coming into and out of corners- banshees will never be the fast bike on the track.- but gearing can help put the power to the groud a little easier some times Quote
tats4life Posted February 12, 2004 Report Posted February 12, 2004 i raced the 4 years of nats, with a duncan national motor geared 16/40. I never seem to ever have a problem. I've never really race a tight track. The tightest track on the nats seems to be round 3 which is echoconee(macon), and that's the track i do the best on. My dr motor was set up more for mid-top than bottom-mid like loren normally does. Quote
tithead Posted February 15, 2004 Report Posted February 15, 2004 i run 14/41 gearing with 20inch rears. it does me fine Quote
streetshee Posted February 15, 2004 Report Posted February 15, 2004 and u can get 120 mph with 14 41? im runnin 17 38 and she runs about 125kmh on the street,absolutly flat out,i only weigh 65kg. are u sure ur tacho is adjusted properly? Quote
