banshee2sick
banshee2sick's Achievements
  1. Ill offer 250 for it.
  2. Man, you guys all sound like you were put under for the procedure! All they did for me was give me local anasthetic. I guess I must have been lucky...I went back to work the same day, didnt really hurt at all. They gave me vicodin es 750's but I didnt even take any of them. As for losing the wisdom teeth making you dumb, it is actually a proven statistic that people that keep their wisdom teeth are more likely to have phsycological problems than those who dont.
  3. I have the 450 shocks, and I have stock arms. The top shock mount needs trimmed very slightly, but I had to move the inside of the bottom shock mount to accomodate for the geometry difference. Also the bottom of the shocks are much thicker, so I had to manipulate the metal in the mount a little so it wouldnt rub. I didnt really notice much of a height increase, and they are definately smoother than stock.
  4. Vitos Performance has them with the stroker plate for 599.95, and it says it requires no other mods. I dont know if theyll ship to your location though. Also, why would you be able to get a crank shipped to you, but not the pistons that are used with it?
  5. What is your evelation?
  6. I think the idea is great!! However, I think the specifics definately need worked out. A big problem is going to be that if everyone sends a vhs tape made with a camcorder, that's exactly what it'll look like...a home video. I'm not an expert in the topic, but I think the quality shots you see in the professionally made movies is controlled in a large portion by the camera and film speed/type. You can count me in, but don't get expectations too high without having the right equipment.
  7. I buy mine at Yamaha of Warren...Its right up the road from my house.
  8. I have both, and I like the v-force reeds very much. As you said though, this is a matter of opinion. It seems like the reak issue with v-force reeds is whether or not it is worth the money or not. I havent heard anyone deny the power increase. I would go with the reeds first. Also, I would find out which domes your head has on it, because if it has the 18cc, 93 octane might not be enough...especially with a +4 timing.
  9. I am running 340's in mine (for the winter) and my mods are very similar to what you have. I agree that it sounds like youre running rich. If you need help jetting give me a call or pm me and I can come out and help you figure it out.
  10. Im not sure what that tube does, exactly. I think it creates some type of airlock. One of mine came off, and I just epoxied it back on. While it was off, it didnt seem to run any different, though. If it is lost, you should be able to go to a parts store and buy a new piece of tubing to replace it. As a side note, please try to watch your typing. It was hard to follow the question you were asking.
  11. I'm not 100% sure, but it's been my experience that no/low backpressure is not good for a motor. Someone will post correction if I'm wrong, but i would get the gap in the exhaust fixed.
  12. I bent my frame around the gas tank the same way. I cut the triangle braces out of the corners, and used a port-a-power to push it back up. then I welded in thicker braces.
  13. What would be a good ratio to use for mx with 20" tires?
  14. I have a N-style Gripper seat cover. It seems to be holding up well (had it about 2 years now) and it keeps you from sliding around. Cold doesnt seem to effect it any.
