MikeyBlue Posted May 31 Report Share Posted May 31 (edited) I’m not sure if this topic has been brought up in the past but……..intermittent CDI?! is this a thing? I have intermittent spark . Everything tests within spec (stator,coil,plugs) pick up gap is set, whole harness has been rung out and cross run. All my grounds are dialed in. Opened up full harness to inspect, nothing fu*ky. Kill switch and key both jumped out. bike runs like a monster then doesn’t want to start, no spark on either side . Push it into the garage and get to in a few weeks and fires right up second kick. Pull the plugs, strong spark. Ride it around the block a few times, run the carbs dry . Let it sit for 15 mins, try to start, no spark. side note: No tors or parking brake. Headlights are also independent from harness. Edited May 31 by MikeyBlue Spelling error Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted May 31 Report Share Posted May 31 Yes common , swap with a known one if possible, is the only way to test. Buy oem only! Used ones are readily available Sent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
MikeyBlue Posted May 31 Author Report Share Posted May 31 @375hp banshees the one from my 97 is not campanile with the plugs on my 96. Do you know anywhere I can get a new oem CDI,? I’m afraid of buying used and having another busted one. Do you trust any aftermarket ones?? Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted May 31 Report Share Posted May 31 No aftermarket ! ... partzilla Its a 3GG-85540-10-00 I thinkOops thats '973GG-85540-00-00Sent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted May 31 Report Share Posted May 31 1 hour ago, MikeyBlue said: @375hp banshees the one from my 97 is not campanile with the plugs on my 96. Do you know anywhere I can get a new oem CDI,? I’m afraid of buying used and having another busted one. Do you trust any aftermarket ones?? I think STB sells adapters, if you think it's worth trying before spending$300+ & might be handy in the future too Quote Link to comment Share on other sites More sharing options...
MikeyBlue Posted May 31 Author Report Share Posted May 31 Good call on the adaptor! Going to order that now. Will keep you posted! Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted May 31 Report Share Posted May 31 Easy to pull the pins on a newer one and put the grey plug on, did it many times a couple weekends ago. Quote Link to comment Share on other sites More sharing options...
MikeyBlue Posted June 13 Author Report Share Posted June 13 Turned out to be a faulty CDI . Pulled the whole harness apart to find nothing. Decided to go with a SOUTH TEXAS BANSHEE drag cut harness to simplify things. I was also able to purchase “what I think” was the last new RevMax Performance CDI . I have this cdi on my 97 that built 100% by Duncan. If they trust it, I trust it! Quote Link to comment Share on other sites More sharing options...
Keno Posted June 15 Report Share Posted June 15 Just adding to this. I've run a Dynatek for like 4 years now. But, it is worthless without a programmer. Super nice to be able to adjust timing with the flip of a switch. Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted June 15 Report Share Posted June 15 I use a MotorCity ignition on my 521 for 2 seasons and im very satisfied.Envoyé de mon SM-S908W en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
