I’m not sure if this topic has been brought up in the past but……..intermittent CDI?!
is this a thing?
I have intermittent spark . Everything tests within spec (stator,coil,plugs) pick up gap is set, whole harness has been rung out and cross run. All my grounds are dialed in. Opened up full harness to inspect, nothing fu*ky. Kill switch and key both jumped out.
bike runs like a monster then doesn’t want to start, no spark on either side . Push it into the garage and get to in a few weeks and fires right up second kick. Pull the plugs, strong spark.
Ride it around the block a few times, run the carbs dry . Let it sit for 15 mins, try to start, no spark.
side note: No tors or parking brake. Headlights are also independent from harness.
