Prime113 Posted July 1, 2021 Report Posted July 1, 2021 I ride in PA so during the summer it gets hot and during the winter it gets pretty cold, so I know I shouldnt run straight water. I am probably gonna end up going 50/50 water and coolant. but I don't know which coolant I should be running. Anybody know a proper coolant? And the water should be distilled water, right? Quote
caleb90 Posted July 1, 2021 Report Posted July 1, 2021 green coolant distilled water. 50/50 all ya need Quote
Prime113 Posted July 1, 2021 Author Report Posted July 1, 2021 6 hours ago, caleb90 said: green coolant distilled water. 50/50 all ya need I can just go buy some normal automotive antifreeze? I was worried that I would need some special motorcycle performance coolant or something like that Quote
Ronniethebigman Posted July 2, 2021 Report Posted July 2, 2021 I use Engine Ice Hi-Performance Coolant 64oz for $24 on Ebay Quote
ClaudeMachining Posted July 2, 2021 Report Posted July 2, 2021 Engine ice is over priced over rated . ^^This.If you need any other stuff than normal 50/50 coolant, you got a problem.Envoyé de mon SM-N975W en utilisant Tapatalk Quote
Prime113 Posted July 2, 2021 Author Report Posted July 2, 2021 1 hour ago, SKEETER said: Engine ice is over priced over rated . I always heard things about engine ice, always wondered why it was so expensive. Seems like its just another one of those things that is more expensive because of the brand name Quote
bluebanshee98 Posted November 6, 2021 Report Posted November 6, 2021 I’m not sure if engine ice is any better then the other stuff out there. Some people say it helps it run a little cooler. Could be wrong though. I do know on DM cylinders they run not when on gas so anything to help keep them cooler would be beneficial Sent from my iPhone using Tapatalk Quote
375hp banshees Posted November 6, 2021 Report Posted November 6, 2021 On 7/1/2021 at 6:52 AM, caleb90 said: green coolant distilled water. 50/50 all ya need Knows PA!! Quote
caleb90 Posted November 6, 2021 Report Posted November 6, 2021 8 hours ago, 375hp banshees said: Knows PA!! Almost spit my coffee out Quote
375hp banshees Posted November 6, 2021 Report Posted November 6, 2021 Key word almost See, i told you practicing swallowing, would be... beneficial Quote
GoatHzb Posted December 20, 2021 Report Posted December 20, 2021 I run engine ice I haven’t ran anything else so idk if it’s bad or not but it does the job Quote
