GoatHzb
Everything posted by GoatHzb
  1. I have 2 different banshee with different problems this one has tors delete and my 2006 that won’t idle that has tors and yes both banshee are synced
  2. I doubt there is nest in the pipes because I pulled the choke half way out and it got a little better it starts up when cold in like 4-5 kicks but I recently put K&N pods on this one to and it takes a a little longer to start now but it still fires up in like 6-7 kicks with choke
  3. No the others thread it’s about my other banshee the one that doesn’t idle is a 2006 with tors system and the one where one pipe only smokes is a 2000 banshee without tors
  4. I have a 2000 banshee the left pipe gives out more air then the right the right gives a little but not as much as the left pipes the upgrades I have are cool head fmf gold series idk what size but I know the sprocket are switched up and a tors delete and extended arms elks shocks
  5. So what size jets should I go with? At the moment I have the toomey t6 jet kit
  6. Yes my air box had a crack in it so I just removed it and installed K&N pods
  7. I run engine ice I haven’t ran anything else so idk if it’s bad or not but it does the job
  8. A new renthal 520 o ring chain is good I just got one on my banshee it loosens up after first ride so make sure to look over it after
  9. No I don’t all I know is it was jetted with the toomey t6 kit
  10. Yes it has stock carbs it was rejetted when I got my t6pipes with tommey jet kit
  11. No I haven’t rejetted it I didn’t think it was nesassary at the time and I’ve never done it before
  12. It starts right up first kick when it dies if I let off the gas but I have to give it throttle when I kick it
  13. I have a banshee with toomey t6 and I just recently put K&N pods on it it used to be kinda hard to start now it won’t start at all unless I push it in 1st and pop the clutch then it slowly starts but won’t idle for more than 1 second ever since I put the pods on I have to stay on the gas or it dies and it pops like a gun shot every once in a while from the exhaust I thought it was the tors system or either the jetting it still has tors on at the moment and I tried adjusting the air and idle screw but won’t get better what whould be the problem ?
  14. I need the lever to I can’t seem to find a good one that come with lever and throttle cable
  15. Yo i need to find A thumb throttle for my banshee it had a wrist Throttle when I got it so I wanna change it I can’t find a throttle that comes with a cable the banshee has a tors delete can you guys give me a part number? I ordered one from partzilla the cable old cable didn’t fit my new throttle
  16. Yeah I also start it and let it warm up before I start riding so it’s the clutch adjustment?
  17. Yes after it gets ridden for like 10 mins it’s good it does that after it sits for a couple week when we ride it after a couple weeks or month for like the first couple times I take off it does that
  18. When I ride my banshee I start it in neutral hold the clutch and kick it in first gear and it dies right when I put it in first the only way it stays on is if I press the gas and let off the clutch at the same time as me putting it in first if won’t stay on if I just kick it in first with the clutch held in what whould be the problem ?
  19. On a 2006 banshee I want more low end power I was gonna change the sprockets and chain. How many teeth should I go for the front and how many teeth for the back sprocket want the most low end power tommey t6 pipes other then that stock
