Ronniethebigman
Everything posted by Ronniethebigman
  1. so the 1990 and up rebuild kits will rebuild the 1989 j-arm brakes? if not which rebuild kit do I get? is it just the way the brakes are mounted on to the j-arm spindles that are different from the a-arm setups
  2. I have j-arm spindles . was wanting to know if the yz450 brakes would work on the j-arm spindles or do I just get a-arm spindles and go from there my brakes are also j-arm style but are in vary bad shape. do they still make rebuild kits or aftermarket brakes that fit the j-arm style spindles
  3. I use Engine Ice Hi-Performance Coolant 64oz for $24 on Ebay
  4. should I get the oem shocks or get these shocks on ebay https://www.ebay.com/itm/310978317698?hash=item4867c08d82:g:8nYAAOSwTzBdlExj
  5. I have tried every thing from het to pb blaster. it still wont move please help
  6. yes a stainless kit and one that has most if not all replacement boults
  7. so I got the ball joints out was not easy at all but I got it. the pb help a lot I even have one of my stuck Rear Shaft Collars drenched in it so I hope it works. as for the stuck hose ill probably have to get a hole new unit because its rounded and there is a long hose attached to it so I cant get a socket on it. that and a set of ebay front brake calipers and MS are not that expensive and there new as far as the pictures go I don't no how to fix that
  8. scroll down you will see it http://www.atv-motorsports.com/mods.html
  9. any one have any ideas to get these off / un stuck I have trayed every thing I can think of
  10. should I sandblast it or just polish it
  11. You are a god i found some on there cheap to
  12. I need stock carburetors or something i got two stock ones but that dont have the throttle cable slides anything will help
  13. Yes i do have Facebook https://www.facebook.com/ronnie.mclaughlin
  14. There like 90 for one i think Ill try to by some on here iv neve Purchased anything on here before And thank you so much for your help
  15. Ok cool i also got them with no throttle cable slides should i get new slides or just get new carburetors
  16. I opened up my carburetors today and seen that I am missing a small copper tub the other one has it but this 1 does not is broken or can I fix it
