375hp banshees Posted October 2, 2019 Report Posted October 2, 2019 You'll have to pull the flywheel & float your ground also to do DCSent from my XT1585 using Tapatalk Quote
kawa110 Posted October 2, 2019 Report Posted October 2, 2019 I’ll take it. Your led bulbs most likely burned out. Sent from my iPhone using Tapatalk Quote
375hp banshees Posted October 2, 2019 Report Posted October 2, 2019 Since AC is so finicky with them, might want to check them on a battery for diagnosing. iirc theyre polarity sensitive Sent from my XT1585 using Tapatalk Quote
JG1 Posted October 2, 2019 Author Report Posted October 2, 2019 11 minutes ago, 375hp banshees said: You'll have to pull the flywheel & float your ground also to do DC Sent from my XT1585 using Tapatalk Oh great. Quote
JG1 Posted October 2, 2019 Author Report Posted October 2, 2019 11 minutes ago, kawa110 said: I’ll take it. Your led bulbs most likely burned out. Sent from my iPhone using Tapatalk I think I still have your addy. Quote
kawa110 Posted October 2, 2019 Report Posted October 2, 2019 ThnxSent from my iPhone using Tapatalk Quote
ClaudeMachining Posted October 2, 2019 Report Posted October 2, 2019 You'll have to pull the flywheel & float your ground also to do DCSent from my XT1585 using Tapatalk Oh great. Hold on!!!!You have 2 ways to get DC on a banshee1- Buy a kit ( https://www.jdscustoms.com/product/jl-engineering-complete-dc-conversion-kit/)2- Do the floating ground mod on your stator.These are 2 differents things!!Envoyé de mon SM-G965W en utilisant Tapatalk Quote
375hp banshees Posted October 2, 2019 Report Posted October 2, 2019 Nope!!!! Sent from my XT1585 using Tapatalk Quote
JG1 Posted October 2, 2019 Author Report Posted October 2, 2019 Is pulling the flywheel and floating the ground a big ordeal? Im learning as I go here. Quote
JG1 Posted October 2, 2019 Author Report Posted October 2, 2019 I might have to redneck it. Lol. Sent from my SM-G960U using Tapatalk Quote
375hp banshees Posted October 2, 2019 Report Posted October 2, 2019 Flywheels easy just get the proper puller&. https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.jlengineering.org/banshee-stator-dc-convers.html&ved=2ahUKEwim-vKnov7kAhVMuVkKHT1jBJYQFjABegQIBhAC&usg=AOvVaw3E_JrHzB5K7vNrG8Ncpd1I&cshid=1570043108666Sent from my XT1585 using Tapatalk Quote
JG1 Posted October 2, 2019 Author Report Posted October 2, 2019 I wonder if the previous ownser didn’t do a DC conversion since he was running leds. I guess theres no way to tell unless I pull the flywheel. Quote
375hp banshees Posted October 2, 2019 Report Posted October 2, 2019 You can look and see what he has for a voltage regulator if it's stock or if it's an aftermarket rectifier/ regulator...You don't have to have the battery like the JL... it's nice but, with the Floated ground and the rectifier, the stator/rectifier just runs your DC circuit separately, ie. your lights Sent from my XT1585 using Tapatalk Quote
JG1 Posted October 2, 2019 Author Report Posted October 2, 2019 The flywheel needs to be pulled to access the voltage regulator, correct? Quote
375hp banshees Posted October 2, 2019 Report Posted October 2, 2019 No, stock location is under the seatSent from my XT1585 using Tapatalk Quote
